Need .8 seconds in 1/4, What mods are next?
Old Oct 10, 2005 | 08:12 PM
jeepramz
Guest
Posts: n/a
Got at best of 13.699 @ 96.73 with 1.8 60ft. What mods do I need now to get in the 12s?
Lets not consider Spray or Boost right now. Any other bolt-ons?
Old Oct 10, 2005 | 08:18 PM
Birdman7389's Avatar
Re: Need .8 seconds in 1/4, What mods are next?
running stock manifolds? A nice set of long tubes would help a BUNCH.
Old Oct 10, 2005 | 08:22 PM
jeepramz
Guest
Posts: n/a
What do you think LTs and a cutout would be worth?
Old Oct 10, 2005 | 08:29 PM
Heatmaker's Avatar
Advanced Member
What's a billet Servo?
Old Oct 10, 2005 | 08:37 PM
jeepramz
Guest
Posts: n/a
Step above a corvette servo for the trans.
Old Oct 10, 2005 | 09:01 PM
96capricemgr's Avatar
LTs for sure.
What converter is that? They are not created equal.
Old Oct 10, 2005 | 09:07 PM
jeepramz
Guest
Posts: n/a
Spec-rite 2800 9 inch lockup.
Old Oct 11, 2005 | 09:52 AM
89385formula's Avatar
LT's, ORY, cutout/or ditch that flowmaster. Some LCA's, and relocation brackets should help get that 60' a little better for you. That should do it for you.
Old Oct 11, 2005 | 11:36 AM
urbaNHunter44's Avatar
am i the only one that thinks he's running really slow for his mods? What altitude are you at?
LTs, dump the cat, cut-out and some suspension mods to get a better 60. You should be close.
Old Oct 11, 2005 | 12:01 PM
Bersaglieri's Avatar
Good Torque Converter - Edge, Vigilante (Never Heard of Spec-rite?)
Longtube Headers
Off Road Y-pipe
Actual 3" catback, not flowmaster
Electric Waterpump
1.6 Roller Rockers
ASP 23% underdrive pulley
MarkyMark is pulling a 12.95 with a stock converter and no roller rockers, so it is possible.
-Dustin-
Old Oct 11, 2005 | 12:03 PM
OutsiderIROC-Z's Avatar
96 mph?
Old Oct 11, 2005 | 01:58 PM
You only need .8 seconds. With that converter and ET streets you should be pulling better than a 1.8 60 ft. I think the LCA's, and Relocation brackets should be able to help you get that 60ft to a 1.6 or so. That equates to .3-.4 at the end of the 1/4 alone. I believe that a good set of LT's, ORY, and cutout, followed by a good tune should get you there. With the rest of the mods others stated you should be deep in the 12's.
Old Oct 11, 2005 | 02:10 PM
Jameslt1TA's Avatar
Ya thats about what mine would trap stock and im at 5500 ft.
What is your elevation. But i do agree get some longtubes and an ory.
Old Oct 11, 2005 | 02:23 PM
camarolover20's Avatar
Headers roller rockers and a tune u will be in the 12's.But then you will want 11's
Old Oct 11, 2005 | 03:46 PM
T/A lt1's Avatar
96mph seems slow for those mods. I think you need to have the car checked out and make sure that everything is OK. The tranny is not slipping or the converter. It should be running 100+mph. Maybe your running at high altitude. Later Clint
