Nasty vibration at 4000rpm
Ever since I've had the car, it's vibrated like crazy starting at around 3000rpm and pretty much getting worse with RPM.
I marked the crank damper with white paint on both the inner and outer ring and sure enough, it slips (I guess they all do at some point). Does this seem like the likely candidate for the vibration?
If so, are any of the cheap aftermarket ones ok, like Dorman, Pioneer, Napa or even GM stock?
Re: Nasty vibration at 4000rpm
The balancer is "0" balanced if it moved, it NO LONGER is "0" balanced,so change it before it shakes your engine to pieces.Or comes in two pieces and tears up the front of the engine.
If that isn't it take the drive shaft loose and turn it 180* at the rear end.
Thanks for the replies guys.
med_reject: I didn't think so either, but I can't figure what else it would be.
97formula1234: I do have a separate, speed-related driveshaft issue (starts around 80 or 85) which, when combined with high RPMs in 4th, is really quite horrendous. But what I was describing can be induced while parked, revving in neutral.
1racerdude: Yeah I recently read that the damper was zero balanced with a pellet weight, so since it has slipped, it's not any longer. Even so, I would be surprised (and happy) if the balancer would cause it to vibrate this badly.
Any comments on which of the above are ok to run? Cheapest?
autoxr166
Sep 25, 2015 04:21 PM
