Name that Camshaft
Old Mar 16, 2008 | 11:05 PM
ulakovic22's Avatar
Name that Camshaft
Hey guys, I have an unknown LT1 camshaft I'm trying to sell and I need the specs. I searched the Comp Catalog and came up with bupkiss. Can anyone help? Cam has the following written on it.
LT1 33165/33175
HR112+4
X2022
Any help is appreciated.
Thanks,
Anthony
Old Mar 16, 2008 | 11:07 PM
GreasyB's Avatar
Might want to just call comp, they would know better then anybody else.
Old Mar 16, 2008 | 11:11 PM
ulakovic22's Avatar
I had subscribed to a thread where Bret had an answer for me in like 2 seconds, but when I went to my subscriptions the other day it wasn't there anymore. Not sure what happened to it, I tried searching and didn't come up with anything. If I don't here anything back I will probably give them a shout after work or something in the next couple of days.
Old Mar 17, 2008 | 07:44 AM
onebadponcho's Avatar
LT1 33165/33175
HR112+4
X2022
Thanks,
Anthony
Anthony,
I'm going to take a stab at this......33165/33175 are lobe numbers. Take the 5 off the end and you have 3316/3317:
3316: 288 adv dur/236 dur @ .050/.521 lift with 1.5 ratio rocker
3317: 294 adv dur/242 dur @ .050/.540 lift with 1.5 ratio rocker
112 degree lobe separation w/4 degree advance ground in.
HTH.
Old Mar 17, 2008 | 11:34 AM
speed_demon24's Avatar
Originally Posted by onebadponcho
Anthony,
HTH.
That should be right, but if you want to be 100% certain you could call up comp and have them send you a cam card if you give them a serial #.
G-BODYT56
Jan 14, 2022 11:14 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
