Mysterious Massive oil leak on top of Valve cover
Old Aug 14, 2007 | 10:24 AM
carolinacasper's Avatar
Help! My car is underivable!
I replaced a rubber hose that is part of the PCV system because it was cracked (line from throttle body to passenger side valve cover) and the rubber grommet that sticks into the valve cover. I placed an inline valve on the hose to attempt to keep some oil from entering the throttle body. I think most people are placing an inline fuel/oil? filter to help with that. Anyways, I messed something up.
I now have a massive oil leak (1 quart every 15 minutes) that sprays on the valve cover and passenger side exhaust header.
I don't know where the leak is coming from. I made sure the rubber grommet is sealing well and that the oil fill cap is on tight.
Is there any other sources of oil on that side of the engine? Should I replace my PCV valve?
Radiator hose blew at the same time too. I don't think its related because those hoses are old.
Old Aug 14, 2007 | 09:56 PM
showstoppers-96-Z/28's Avatar
Clean the engine off with a de-greaser (brake clean works well and is non-flamable) then start the car or have someone do it for you, get out and see what you can see, the location should be relatively obvious, other than that. Idk what randomly SPRAYS oil other than the sending unit (which is under oil pressure).
Old Aug 14, 2007 | 11:40 PM
JP95ZM6's Avatar
Is that valve you put in closed? If so, with blowby past the rings, I think you would pressurize the inside of the engine, and the gasses would have to escape somewhere. Like the grommet, or the oil fill cap. And a lot of oil might go with it. Dunno, but if the valve is closed, open it.
Old Aug 15, 2007 | 11:41 AM
matLT1's Avatar
It could be that the check valve you installed in attempt to stop the oil from entering the throttle body is now causing the engine to build pressure. Try removing this check valve and see what happens.
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
