Is My Waterpump History?
Old Aug 6, 2003 | 09:47 PM
ONELOUDKAR's Avatar
Angry Is My Waterpump History?
Stopped to get gas, started the car back up and the temp pegged 260* got home and let it cool down, took off the cap.....
no water what-so-ever in there. I put 5 cup fulls of water in there and started the car up and looked under it, and there came the water pouring out!!! Is this a sign that it is history? If so, where and which one should I go with?
thanks,
-Mike
Old Aug 6, 2003 | 09:56 PM
jasons93z's Avatar
where exactly was it coming out at? It could be something else.
Old Aug 6, 2003 | 09:57 PM
Fuels94TA's Avatar
Well if the coolant is coming out of the weep hole in front of the water pump, yes it's shot. I've went with a stock remanufactured 3 years ago and still working.
Vinny
Old Aug 6, 2003 | 10:26 PM
notstock4long's Avatar
Yeah, if it is coming from there, then it's the water pump. Autozone replacement is only $50 with a lifetime warranty.
Old Aug 7, 2003 | 07:15 AM
ONELOUDKAR's Avatar
not exactly sure where it was coming from as of last night, but like 2 months ago, a friend of mine noticed it leaking and he got up under there and saw where it was coming from. He said it was the waterpump and he is pretty good when it comes to cars. So I need to know.... go with a electric one or stick with the stock one? Is it a do-it-yourself job or should i have someone do it?
-Mike
Old Aug 7, 2003 | 09:21 AM
I would say stick with the stock one. They are cheaper, and a little safer I think. If the electric one goes bad, you will lose your coolant a lot faster, and possibly wreck something else if you don't catch it right away. You would gain 5-7 hp with an electric one, but I don't think it is worth it.
You could do the swap yourself. It isn't too hard. Let me know if you have any questions about the install.
Old Aug 7, 2003 | 09:25 AM
ONELOUDKAR's Avatar
My mechanic said he would do it for $150.00? Does this sound like a good deal? Would save me some time that I really dont have. Where did you pick your up at and how much? I was told
to buy a new one, not a re-made one.
Thanks,
-Mike
Old Aug 7, 2003 | 12:30 PM
Remanufactured water pumps are fine. They were originals at one time, and plus they have lifetime warantees. I got mine from autozone for $49.95 plus the core. $150 sounds decent, since it would probably take about three hours if you have some experience. So at basic mechanic rates, that is a good price, he isn't ripping you off or anything.
Old Aug 7, 2003 | 12:34 PM
ONELOUDKAR's Avatar
yea, i was checking with autozone also and that is what they were quoting me. I am not sure about getting a re-make though. how long have you had yours?
Old Aug 7, 2003 | 12:37 PM
A remake will be fine. I have only had mine for about 2,000 miles, but the last one was a reman. and had been in for over 50k. It wasn't even bad when I replaced it, I had the motor out so I figured I should get a new one. And an original gm one will be a hell of a lot more, and I doubt it comes with a lifetime warranty.
reww86
Aug 29, 2015 06:04 PM
TGGodfrey
Aug 18, 2015 06:08 PM
MikeWhitener
Aug 2, 2015 06:17 PM
ChrisFrez
Mar 1, 2015 01:33 PM
