My Tranny!!! Need urgent help !!! Belhousing
Old Jun 11, 2003 | 11:54 PM
96redformula7's Avatar
I went today to the shop to see why I was leaking tranny fluid, like a dime size amount. Well it turns out that it is leaking out the front seal. Anyways, My bellhousing has a crack like 4 inches long on each of the two sides. I NEED ADVICE. I am probably leaning towards replacing the tranny from what people are telling me. What do you all think? How much am I looking at to get it repaired or to get a new tranny and labor?
Old Jun 12, 2003 | 01:39 AM
Oh come on, some of you have to know something about it.
Old Jun 12, 2003 | 04:04 AM
revtime's Avatar
Ok, I am reluctant to advise you to use the cracked case, it can be repaired but I would not do it.
A new tranny is probably the best way to go here.
Old Jun 12, 2003 | 07:01 AM
bad79z28's Avatar
I would have the trans shop weld the case back up. I've had it done many times and never had a problem.
Kevin
Old Jun 12, 2003 | 11:39 AM
revtime's Avatar
I have seen it done too, but I would be reluctant to do it.
But it probably would be alot cheaper, I had my tranny rebuilt carryout for 750. Welding yours up and having it rebuilt while its out would be the cheapest way to go.
Old Jun 16, 2003 | 12:42 PM
Can i just replace the case?
Old Jun 16, 2003 | 02:14 PM
nobody???
Old Jun 16, 2003 | 06:51 PM
bad79z28's Avatar
You can either replace the case or repair your case or replace the entire transmission. A reputable transmission shop should be able to steer you in the right direction.
Kevin
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Bxlt1
Sep 29, 2015 03:18 PM
drt
Sep 27, 2015 04:39 PM
z28newbie
Sep 9, 2015 10:26 AM
