is my tps voltage right?
Old Nov 15, 2004 | 07:44 PM
1badasZ's Avatar
on the scanmaster at idle its .82 and at wot its 4.49. is this right? and if not could it have an effect on wide open throttle shifting?
Old Nov 15, 2004 | 07:54 PM
Brent94Z's Avatar
Super Moderator
Re: is my tps voltage right?
That should work just fine for you. I've had mine as high as .9 and as low as .24 and no problems... in each case I was getting 0 to 100 TPP and no SES.
Old Nov 15, 2004 | 07:56 PM
As long as your scanner shows 0-100% throttle angle, it should be ok. The sweet spot for 0% angle seems to be .50v-60v.
Old Nov 15, 2004 | 08:00 PM
1badasZ's Avatar
no it hasnt given any codes and the % does go to 100
truecontr3
Oct 11, 2015 09:30 AM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
Aug 7, 2015 01:26 PM
