my t56 is trashed heres pics
Old Jan 14, 2004 | 10:01 AM
  #16
Rodrigues's Avatar
What does it do when you press the clutch in and try and go into second gear? Thats the syncronizer trying to mesh...
Originally posted by 97SS0594
on this note my 2nd gear dont work, but if im stopped and hold the shifter against 2nd w/out the clutch depressed the car will roll slowly forward, is it just my shifter fork or is the whole gear destroyed??
Old Jan 14, 2004 | 10:26 AM
  #17
FireAm94's Avatar
97SS: sounds like when my clutch went out....take the dust shield off and see if fibers fall out....also check your hydraulics...that's what happended to my f150....slave cylinder started leaking and same stuff.
Joe
Old Jan 14, 2004 | 04:48 PM
  #18
97Z-M6's Avatar
it does fine in second, shifts great just that reverse thing i was telling you about. ive been to the track with it and never missed shifted.
Old Jan 14, 2004 | 07:01 PM
  #19
OutKast's Avatar
If you're going to part it out I would be very interested in the front plate.
Old Jan 14, 2004 | 07:43 PM
  #20
Compstall's Avatar
Quick! Put it back in there and act like you never saw anything!
Old Jan 14, 2004 | 09:15 PM
  #21
Vader's Avatar
Like I always say, when you can see part numbers on the busted bits, its bad.
Old Jan 14, 2004 | 09:47 PM
  #22
97Z-M6's Avatar
well i just wemt and picked it back up, and he said it will run and run ok but forth gear will make some noise. but when i took it to him you could hold the input shaft and and hold the out put shaft and turn one and you could tell it had some slack in it but now theres no slack at all when you do it.
Old Jan 14, 2004 | 10:04 PM
  #23
Steve in Seattle's Avatar
ouch. sure looks like a syncro bit the dust. Not sure what the rest of that is (just collatteral damage I'd guess... like the gear teeth getting chipped while trying to spin in that garbage).
If you plan on parting it out let me know. I'm in the market for a T56 extension housing.
Old Jan 14, 2004 | 10:09 PM
  #24
GreenDemon's Avatar
That looks pretty freaky...
Anybody got any pics of what an auto looks like when it breaks???
Metal Soup???
  #25
Robert95z's Avatar
Originally posted by RE AND CHERYL
I ain't no transmission repair man, but that don't look good.
Old Jan 14, 2004 | 10:29 PM
  #26
Looks like someone swept the machine shop floor and dumped it in your tranny. Time to learn something about the innards.
Old Jan 14, 2004 | 10:38 PM
  #27
97Z-M6's Avatar
quite the oppisite: he open the tranny dump the crap ut of it then swept the shop floor.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Devinfoote87
Parts Wanted
Apr 14, 2015 04:29 PM
nikolt1
Feb 27, 2015 09:10 PM
