Are my rockers too tight ??
Old Sep 3, 2004 | 01:31 PM
Mystic97Z's Avatar
mods in sig, comp 1.6 rockers on comp r lifters. when we installed them, my dad went to zero lash, then did 1 full turn. i've been reading lately their only supposed to be 1/8th of a turn past zero lash. my dad said 1 full turn will the the piston inside the lifter to the middle of the bore, and thats where its supposed to be, he said if they were too tight i would be having other problems. i'm not having any problems per say, but i think my combo should be making more power, and just trying to figure stuff out..how should they be adjusted or tightened? thanks
-Jason
also, if they were too tight, would i be losing power?
Old Sep 3, 2004 | 01:49 PM
BUBBA's Avatar
Re: Are my rockers too tight ??
Generally one full turn past 0 is too much for best power. I believe that is what the factory sets them at.
1/2 turn is usually recommended, however some go as little as 1/8 when the valves are closed and the cam lobe for that particular cylinder is on the base circle. JMHO
Old Sep 3, 2004 | 04:32 PM
Mystic97Z's Avatar
u think it'd be worth it to redo them? or no really noticable gain?
Old Sep 3, 2004 | 04:41 PM
BUBBA's Avatar
Yes.
What method did you use to do it the first time?
Old Sep 3, 2004 | 05:21 PM
One turn is not recommended for Comp R's. In my testing, they only had ~1¼ turns of complete travel with 7/16 rocker studs, so you could be close to having them so tight that you could cause damage to them. There have been so many rocker tightening threads lately, it's not even funny. Back them off to 1/8 and see how she goes.
Old Sep 3, 2004 | 10:28 PM
TQdrivenws6's Avatar
That is way too tight for Comp Rs. Most people have the best luck closer to 0 lash, but you can go as far as 1/8 turn as previously mentioned.
Yes you could be seriously down on power if you have Comp Rs at 1 turn past 0 lash.
Old Sep 3, 2004 | 11:00 PM
LT1Squirrel's Avatar
yeah.....dad's think they know everything....like when they think your car is loud enough.....maybe by their standards
Old Sep 3, 2004 | 11:08 PM
LOL, you don't have to be a dad, not to know how to adjust Comp R's. Just look at the many threads dealing with the subject.
I plan on passing this info down to the next generation:
Me: Pay attention now, this is how you set the lash on Comp R lifters.
My grandson: Goo!
Old Sep 4, 2004 | 12:51 PM
Mystic97Z's Avatar
well he's a tech so i think he knows more than me..
Old Sep 4, 2004 | 06:30 PM
NightTrain66's Avatar
Do a search and you will find ALOT of people that have mis adjusted R lifters. Most people claim a big HP increase from having them 1/4 turn past zero and then adjusting them to 1/16 turn.
The Comp R lifters are very picky about adjustment and it is not that your dad is dumb or anything, the R's are just VERY picky about adjustment.
Lloyd Elliott
NightTrain66
13qtr
Oct 28, 2016 08:11 PM
IndyZman
Oct 22, 2015 02:17 PM
95chwagon
Oct 16, 2015 12:24 PM
football4life
Oct 4, 2015 07:48 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
