My reverse lights dont work 95 Z M6 help please!
Old Mar 22, 2004 | 09:40 PM
CJ Black LS1 Z28 M6's Avatar
Thumbs down My reverse lights dont work 95 Z M6 help please!
Well I had this problem on my old 99 LS1 6-speed Z. But I had the dealer take care of it under warranty back then. Now on my current 95 Z Im going to have to fix it myself. I changed the bulbs but still no good. I did a search and seen the T56 has reverse lights wiring somewhere underneath. Could this be the culprit? Thanks in advance
Old Mar 22, 2004 | 09:50 PM
jsz28's Avatar
Have you checked the fuse.
Old Mar 23, 2004 | 01:28 AM
Jason Dove's Avatar
There's a solenoid in the tranny that you can remove and check. Check for that before you go checking the wiring. There's instructions in the Haynes manual if you have one.
Old Mar 23, 2004 | 02:55 AM
97SS0594's Avatar
mine dont work either!! i just let it go, i would like to know how to fix it though!!
Old Mar 23, 2004 | 03:51 AM
HBHRacing's Avatar
I would check for power at the brown wire at the back up light switch with the car in rev and then see if it comes out on the green wire. thats the best place to start
Old Mar 23, 2004 | 11:10 AM
speed76demon's Avatar
Well I have a problem with mine too. One of them works and the other doesn't. I have changed the one that doens't work like with 4 different bulbs none of them worked. I wish I knew what was wrong with it
Old Mar 23, 2004 | 12:47 PM
Well looks like ill be paying for a inspection sticker again Might as well order the long tubes and sh*t while im at it
Old Mar 23, 2004 | 02:41 PM
Jason Dove's Avatar
Did you check the reverse solenoid in the tranny?
squarehead
Jan 15, 2015 07:02 PM
Collector Car
Jan 5, 2015 10:58 AM
fpete1992
Dec 11, 2014 03:51 PM
A's 91 Z28
Dec 7, 2014 12:09 PM
siguy
Nov 27, 2014 10:07 AM
