My Old Lloyd Elliot Heads & GM847 Cam Dyno results!
Old Jul 21, 2004 | 11:19 PM
bunker's Avatar
[B]My Old Lloyd Elliot Heads & GM847 Cam Dyno results![/B]
Here are some old dyno results, the AFR readings was separate as they weren't using a Dynojet for AFR but a separate wideband, the AFR was around 12.8:1 accross, I was going to post these a while back but totally fergot, this is with the 847 cam, I now have the LE3 cam which I hope will make more power next weekend, I must saay the dyno graph is pretty smooth.
http://www3.telus.net/bunker/DSCN00551.jpg
Matt.
Old Jul 21, 2004 | 11:25 PM
atljar's Avatar
Re: My Old Lloyd Elliot Heads & GM847 Cam Dyno results!
Looks good matt, did you get any SAE/STD numbers
Old Jul 21, 2004 | 11:27 PM
flyinZ's Avatar
Doesn't look too bad..
bunker's Avatar
no, but I assume the STD numbers would be higher while SAE would be lower, this was about 3 month back, SAE was almost 400rwhp lost that sheet. THis is also with 4.10 gears & heavy ZR1 wheels.
StansZ28
Feb 19, 2015 07:39 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
birdblack
Dec 30, 2014 06:59 PM
Queens94z28
Nov 20, 2014 06:03 PM
