Is my oil pressure low at idle?
It's a rebuilt to stock LT1. Standard pump and everything. I have drove it maybe 100 miles. When cold the pressure is great. After the engine is hot driving it will run about 45-50 but when I'm at an idle in gear "automatic" hot it will get down to 25-35 at 600 RPMs. Does that seem low at idle when hot or is that normal?
If it was below 10psi at idle I would maybe start to get concerned.
it's never been that low. i think 25 is the lowest it has been at idle.
25psi at hot idle is lots. You have nothing to worry about.
That pressure seems normal to me.
Originally Posted by mvvette97
(Post 5966471)
The normal range when hot with a stock pump that ive seen is 15-18 psi .... and 25 is really good for a stock pump..
(Post 5966471)
You do NOT have a problem
Originally Posted by shoebox
(Post 5966607)
That's pretty good idle pressure.
good to hear. I'm kinda new to LT1s so I wasn't sure. The only reason I was wondering is because my LS1 never gets below 40 psi but I guess every engine is different
