My new engine is overheating. Help!
Old Jun 17, 2005 | 11:02 PM
bluelt1z28's Avatar
I have about 3000 miles on my new 383 supercharged engine and I installed a 160 thermostat and a csi electric water pump. The temp was normal until recently. When I am in stop and go traffic the temp rises up to the red mark, but when I get on the freeway or at higher speeds it drops slowly until I am at idle or in stop and go traffic then it rises again. At first I thought I had air in the system, so I bleed it, but it did'nt take care of it. Could my water pump be going out after 3000 miles? Could something else cause this? I also changed the thermostat.
Old Jun 17, 2005 | 11:10 PM
OBE1 95Z28's Avatar
Re: My new engine is overheating. Help!
3,000 miles ago I assume the weather was cooler. Is it only happening on hot days? How much does the temperature rise? Even a stock motor will get a temperature rise in stop and go traffic.
Old Jun 17, 2005 | 11:51 PM
NewbieWar's Avatar
temperature rise? lol talk about overheating... that thing needs to be air cooled
Old Jun 17, 2005 | 11:52 PM
bluelt1z28's Avatar
All the way to the red line
Old Jun 17, 2005 | 11:53 PM
NewbieWar's Avatar
yea mine is stock and it does that... i'm looking to get a elecric water pump... and coated headers...
you have to remember, when you increase your PSI, on your motor, the air heats up... not exactly sure how much, but it is substantial. this is one advantage of a intercooler. and when its already hot outside 90* plus weather, it might be 105* or even more by the time the valve closes.
then its hotter as the air comes out the exhaust (than w/o the supercharger) and then heating up your engine bay more... and now ur outside air is hotter...
lol, its a bad system, but without you moving, you will probably overheat yes...
(granted. none of this is sourced from anywhere I'm just using my imagination of the process, and my limited knowledge of science)
Old Jun 19, 2005 | 02:44 PM
xtremetrans's Avatar
There was no change in weather from one day to the next.
Old Jun 19, 2005 | 02:50 PM
lt11997's Avatar
At what temp do you have your fans coming on.
Old Jun 19, 2005 | 02:57 PM
jpolz's Avatar
Are you sure your fans are coming on at all?
Old Jun 19, 2005 | 03:03 PM
I know the fans are coming on, I checked them when I saw the temp go up, but I dont know at what temp. they came on.
Old Jun 19, 2005 | 03:05 PM
jpolz's Avatar
Try grounding the fan leads to stay on all the time and see if you still overheat. That should tell you if your fans are the problem or not.
Old Jun 19, 2005 | 03:44 PM
baddboy1705's Avatar
Just went through the same problem, though I was having trouble getting my heater to blow hot heat and it was overheating as well. If you are 100% sure that everything is in working order(thermostat, waterpump, nothing clogging your system) then bleed your system. I know it seems like that wouldn't help any, but air in your heads would cause your problem. I had to bleed my system 8 different times to get all of the air out. So after you think you've bled your system enough, did it 3 more times... hopefully this will solve all your problems, Good luck
http://shbox.com/1/4th_gen_tech2.html#radflushmy system
-Jeremiah
baddboy1705@aol.com ---if you need anything else
Old Jun 19, 2005 | 03:56 PM
fireman's Avatar
Try this stuff---www.evanscooling.com
Old Jun 19, 2005 | 05:44 PM
TUNDRKYS's Avatar
-Jeremiah
You know I've tried bleeding my system the way they say on that website, but I've never been able to run my car with the Radiator cap off. Once the car gets to operating temp, water starts gushing out, till I have to shut the car down. I know this can't be right.
Old Jun 20, 2005 | 12:14 AM
worked for me just fine...but i didn't do the rad cap thing, i left it on and used the two bleeder screws, just thought the link would help out, I found it after I fixed my problem...
-Jeremiah
Baddboy1705@aol.com
Old Jun 21, 2005 | 08:17 AM
Luna's Avatar
Sounds like the pump isn't working, thermostat is stuck or you have the pump spinning in reverse (change the polarity of the electrical leads)
