My new best at the track (vid)
Old Nov 17, 2004 | 07:50 PM
speed_demon24's Avatar
http://www.p-r-o-s.net/movies/ROBMOROSO.mpg
I think the transmission is going out though. The 1-2 shift takes forever and you can hear it tap the limiter right before it shifts into 2nd gear.
Old Nov 17, 2004 | 07:54 PM
Spinner's Avatar
Re: My new best at the track (vid)
Running great, all things considered
Old Nov 18, 2004 | 02:10 PM
skibbe_96z's Avatar
Nice run. You got a 12.56 without a stall converter in your A4. Very impressive.
I have never ran my car but the guy I bought it from said his best was a 13.4 and I am thinkin that he might have ran it on a bad track or something. I was thinkin that I should be running around a 13.0-13.2. This summer I will be installing a cam and upgradeing to long tubes so I hope to be running low twelves. The cam is going to be an XR227 or an XE227.
Old Nov 18, 2004 | 03:57 PM
TEAMJESUS316's Avatar
GREAT TIMES,WHAT WERE YOUR 60 FT TIMES AND DO YOU HAVING THE 3.73 GEAR HELP YOU BY NOT HAVING A STALL AS FAR AS LAUNCH GOES?
Old Nov 18, 2004 | 04:52 PM
cndctrdj's Avatar
nice run that thing pulls hard all the way form what i could see
Old Nov 18, 2004 | 04:56 PM
Loony's Avatar
Your friends sound like pot heads
But on another note, car looks strong man, very nice. And yes, that was a very nice burnout
Old Nov 18, 2004 | 05:17 PM
I would think they did, but I thought I would have cut a better 60' that I did. It was a 1.862 dead hooking. With 3.23's and goodyear gsd3's I cut a 1.917 with no tire spin easing into the throttle. I'm probably going to change the tranny fluid and have brian check out my tune to see if anything is wronge with it and head back out once it gets cold here and hit some 12.4's-12.3's.
Old Nov 19, 2004 | 08:39 AM
kevm14's Avatar
My 93 Caprice's 4L60 has shifted the 1-2 like that since I got it at 113k. Haven't done a fluid change since and it still shifts like that at 206k. I suppose having a weak stock L05 might help it live longer. The odd thing is, when the fluid is cold, the 1-2, especially at part throttle, is VERY crisp. Almost too crisp. As in, break the tires loose on wet pavement...oh well.
Old Nov 19, 2004 | 09:05 AM
RedHottG2's Avatar
Strong run there buddy!! a little tranny work and 11's shouldn't be to far away.
Old Nov 19, 2004 | 09:51 AM
aintno6's Avatar
I would have your shiftpoints looked at. My car would shift like that , then once I got the shiftpoints fixed it went away.
Old Nov 19, 2004 | 02:38 PM
I have a PCM for less tune and when I first got it it was shifting at 5800 every shift in every gear. I thought that was too early to shift anyway, and it just kept gradualy shifting later and later and I really didnt think anything of it until it started hitting the limiter. It doesn't always do it though. It has only done it a total of 4 times, and 2 of them were at the track, it did it both runs.
Old Nov 19, 2004 | 08:44 PM
joecool72's Avatar
Nice run man! As said with all things considered, I'm sure better times await in the future! Saweet!
Old Nov 19, 2004 | 09:07 PM
Antz97ZNJ's Avatar
nice run
Louey
Pacific
Oct 1, 2015 12:37 AM
NewsBot
Sep 16, 2015 10:30 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
Louey
Pacific
Sep 1, 2015 07:19 PM
Louey
Pacific
Aug 25, 2015 01:53 AM
