My leaking WP.
Old Feb 22, 2007 | 02:03 PM
sandman63's Avatar
My leaking WP.
Well this is a shot i took just before i put the car away. Iam just wondering if its just the gasket thats gone, the car doesnt over heat at all either, just wonder whats the deal here?
Old Feb 22, 2007 | 02:04 PM
2000GTP's Avatar
It looks like it is spewing out of the weep hole, time for a new water pump.
Old Feb 22, 2007 | 02:20 PM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
Everytime I click that link it takes me to hotmail.
sandman63's Avatar
Yeah it does, but then why would the right an left bolts be soaked?
Old Feb 22, 2007 | 02:26 PM
camarozz95's Avatar
Similar thing happened to me it thought it was coming from the weep hole, but i started the car and looked under there and I could see it coming out where the pump meets the block. turns out the gasket was totally shot when I took it off so I replaced the gasket and also replaced the waterpump since I had it off.
Old Feb 22, 2007 | 02:41 PM
sandman63's Avatar
Yeah iam gunna replace it when i take the car out, but just wondering what you guys thought before i did anything.
Old Feb 22, 2007 | 03:04 PM
danhr's Avatar
*ahem*
http://web.camaross.com/forums/showthread.php?t=503979
Old Feb 22, 2007 | 06:02 PM
sandman63's Avatar
Originally Posted by danhr
I was thinking of a E-WP too, lol.
Old Feb 22, 2007 | 06:44 PM
danhr's Avatar
you could put the electric water pump in this one, so that way you will have less of a "down time" for your car?
Old Feb 22, 2007 | 08:40 PM
sandman63's Avatar
Yeah but how long does it take to change a WP? lol.
Old Feb 22, 2007 | 08:45 PM
mdacton's Avatar
well you need to plug the water pump housing, I would take the drive out but you will have to take off the timing cover and timing set...plug the holes
I guess you could just pull the housing off and put the e-pump kit on and wire it up....leave the drive in the block and just plug the housing if it will fit that way...i'm sure it will
Old Feb 22, 2007 | 08:58 PM
Z95m6's Avatar
It will fit that way. My buddy ran his CSR for a while before he did his cam swap and ditched the water pump drive. I plan to install a new cam and e-waterpump this weekend. I'm going to keep the LT4 ED chain and the drive in place. This way if i ever get stranded out of town or something i can just swap in a stock pump and get going.
Old Feb 23, 2007 | 10:51 AM
sandman63's Avatar
Ohh okay, but is it really worth going to E waterpump over just a stocker?
Old Feb 23, 2007 | 11:03 AM
2000GTP's Avatar
There is a gain to be had by swapping in an electric pump, close to 10 horse at the wheels in most cases. If you are trying to squeeze out every last bit from your motor, then it may not be a bad idea.
Old Feb 23, 2007 | 11:06 PM
Finchinater's Avatar
How is it that the original link goes directly to my hotmail inbox?????
I've never seen this. I checked this thread out because I think mine is leaking also and the link goes to my hotmail account.
Contacting some of the higher ups.
Jeff1904
Jun 5, 2016 05:00 PM
magman
Apr 15, 2016 03:08 AM
blac94Z
Nov 4, 2015 01:59 PM
drt
Sep 27, 2015 04:39 PM
colts0455
Sep 27, 2015 01:07 PM
