my electric fans run all the time on LOW...
Old May 23, 2003 | 02:30 PM
yorkie's Avatar
then when they reach temp, they turn on loud and cool the motor down then go back to low speed, What is it, the water pump temp switch bad??? No check engine light or codes.
Eric
Old May 23, 2003 | 02:39 PM
Maybe you have a ground on one of the relay leads or you have a stuck relay. Try swapping relays around.
It would help to know what year car and how many fan relays you have.
Old May 23, 2003 | 02:43 PM
yorkie's Avatar
Its a 1995 z-28 and has ...
dual fans, so I assume two relays, but both fans turn at low spped???
Old May 23, 2003 | 02:46 PM
Re: Its a 1995 z-28 and has ...
A 1995 will have 3 relays. Both fans are supposed to run at low speed on initial engagement.
Old May 23, 2003 | 02:51 PM
yorkie's Avatar
I just swapped the #1, and #2 around...
started car and both fans were off then they both came on at LOW speed and then as it got a little hotter it came on LOUD and cycled to back to LOW speed.
Old May 23, 2003 | 02:53 PM
yorkie's Avatar
low speed initial engagement?
explain? I thought they were off and then come on, turn off.
Old May 23, 2003 | 02:57 PM
yorkie's Avatar
Smile yes it has #1, #2, #3... explain...
Old May 23, 2003 | 02:58 PM
If there is nothing wrong with the fan circuits, it might be the temp sensor in the water pump.
Here is a schematic for the fans. Use the lower one that has the three relays.
Here is info on testing the sensor.
It would be nice if you had a scan tool to tell you what the pcm is reading as engine temp. That would tell you if the temp sensor was a problem.
Old May 23, 2003 | 03:00 PM
yorkie's Avatar
no scan tool, it has a 383 engine and tuning...
by pcmforless.com, Brian is not sure either.
Old May 23, 2003 | 03:05 PM
yorkie's Avatar
I am not getting a check engine light
I had one of these switches bad on a Turbo Trans Am and it would show good when the test was done but I got a new one and it was the culprit.
Old May 23, 2003 | 04:04 PM
yorkie's Avatar
so it is normal for the fans...
to run on low? As I said they are off when I start it, let it idle for a while and they come on low speed? Then it cycles on and off on HI speed, but the low speed always stays there??
Old May 23, 2003 | 04:19 PM
yorkie's Avatar
just as the temp goes above the 160 mark on the factory guage...
the fan turns on, but low, then as it gets to the second mark on the factory guage it turns on high speed, cools down, turns back to low speed???
Old May 23, 2003 | 04:57 PM
Any custom programming in the pcm?
You need to monitor it with a scan tool to see what the pcm is seeing.
Stock, the pcm will command low speed fans "ON" at 226º and "OFF" at 221º and high speed fans "ON" at 235º and "OFF" at 230º.
Old May 23, 2003 | 05:13 PM
yorkie's Avatar
sounds like it is fine then...
Has a 160 thermo and been programmed by pcmforless for the 160 thermo.
Old May 23, 2003 | 05:18 PM
yorkie's Avatar
so it does have a low and high????
then it sounds perfect, when cold all fans are off then the low speed comes on, and when it gets hotttt the high speed come on and go off, but the low speed stays on, once winter gets here then the low speed will cycle too it sounds like.
