my dyno #'s / chart LE Heads/357 ci.
Old Aug 14, 2005 | 12:27 PM
Mystic97Z's Avatar
97 6 speed z28
Lower end:
Bored .40 over
forged scat crank
forged J&E pistons 10.5:1
Forged 6" eagle H beam rods
Top End
LE 1 heads flowed around 274
Fierra valves
236/245 .579 lift 111 lsa
Full comp valve train
Exhaust:
Hooker Longtubes
Hooker off road Y
Borla
Intake:
stock lt1 intake
bbk 58mm TB
Slp Cold Air
Misc:
accell 30# injectors
taylor wires
Best pull was 376 rwhp....
car seems to be mis-firing or something around 5300 rpms or so..it -sounded- smooth on the dyno, it wasn't sputtering or anything. i have a mail order tune from madz28. i was hoping for 400 rwhp. i think if i get this mis-fire straightened out, i will be pretty damn close to 400. then a dyno tune will hopefully put me around 415-420 or so...what ya guys think?
Dyno chart:
http://www.pix8.net/pro/pic.php?u=12089N96hP&i=591701
Pics of the car:
http://www.pix8.net/pro/pic.php?u=12089N96hP&i=539636
http://www.pix8.net/pro/pic.php?u=12089N96hP&i=569853
http://www.pix8.net/pro/pic.php?u=12089N96hP&i=569862
http://www.pix8.net/pro/pic.php?u=12089N96hP&i=569854
Old Aug 14, 2005 | 01:16 PM
blackztpi's Avatar
Re: my dyno #'s / chart LE Heads/357 ci.
thats a lot of cam for LE1 heads. the heads are probably slowing you down as well.
Old Aug 14, 2005 | 02:03 PM
guywithaZ's Avatar
I don't know where Imperial is but if I end up there I'll know not to race you ...
Old Aug 14, 2005 | 02:08 PM
Turbo6's Avatar
Are you sure the LE1 heads flow that much. His higher end heads flow in the upper 270's, I can't believe the stage one's flow that much. I think they should be around 250 or so, right?
Also, why stock compression? You could be running at least a point more compression (11.5) on pump gas. There's 3-5% more power right there.
Old Aug 14, 2005 | 05:00 PM
93turbo5oh's Avatar
have any of you guys flowed the LE heads on an independant bench?
Old Aug 14, 2005 | 05:32 PM
Kurt Crosbie's Avatar
Possibly he did not give the flow at the correct lift...?
Old Aug 14, 2005 | 05:37 PM
simple's Avatar
looks like its breaking up after 5200 or so...
you could probably also use some 36lb injectors
tuning will definately bring out more in it!!
Old Aug 14, 2005 | 07:16 PM
94 TA TT2S's Avatar
says LE2 in his sig....Probably just mistyped it......
Old Aug 14, 2005 | 07:17 PM
Mystic97Z's Avatar
ya they are le1 heads, well i got them like a year and a half ago and i think since then they got a little more -tame- if you could say. i think the le1 heads is just p+p. i got the p+p job + the larger valves..so maybe le2.
my engine builder as well as combination motorsports said not to run any higher than 11:1 on pump gas. going to check my logs now to see if it is fuel related or ignition related..
Old Aug 14, 2005 | 09:04 PM
Sneakin Deacon's Avatar
seems to be a whole lot of variation in power. i understand you will lose some cause those 3 runs were done in like 3 minutes...but the 2nd and 3rd run had substantially more area under the curve in the lower rpms. as for the breaking up, did you datalog at all, or notice any black "puffs" of smoke through the tail pipes? looks like possible spark retard.
as for your 400rwhp estimation, i do believe with the stutter issue resolved you could be looking at the 390 range. and a dyno tune you should be where you are looking to be. honestly, that cam, and those heads, i would expect to be no less than 420. but it depends on your accompanying mods (such as get a ported intake) and it also depends on weather conditions there aswell, SAE numbers are good to compare, but actual conditions are what will affect your motor. just to say, it could be a cold day, and youre running a little leaner, and it gives ya that umph, and toss a little spark retard in there, the SAE numbers wont account for your computer pulling timing.
and for your compression, they might be referring to your DCR, not SCR. i would get in contact with them and find out.
Old Aug 14, 2005 | 10:03 PM
93turbo5oh's Avatar
not exactly, ive seen a pair of his heads flow less then advertised. i think his bench might be a little optimistic.
Old Aug 14, 2005 | 10:37 PM
madwolf's Avatar
Your injectors are delivering enough fuel. It is running a bit rich for a little while, but leaning that out won't make a big difference. Maybe 10 RWHP at the most. You have some other issue at higher RPM. Looks most likely ignition related.
Old Aug 15, 2005 | 12:05 AM
Mystic97Z's Avatar
ya i did data log them, had my dad look at it tonight..he's an ase tech.
looks like it IS ignition related, not fuel. the car has the original coil at 135,000 miles..going to replace that and then go from there...
any suggestions on coils? just get an ac delco one?
Old Aug 15, 2005 | 12:07 AM
simple's Avatar
delteq
Old Aug 15, 2005 | 12:29 AM
Cmr0z28's Avatar
I would use only an OEM AC Delco replacement...especially in a 96-97 since the stock coil is very good. None of the aftermarket ones seem to last too long.
