My car makes a funny noise when I take off.
Old Jun 27, 2003 | 09:10 AM
MetallicTrans96's Avatar
When I take off from a stop sign or just out of my drive my car makes this noise in my rear end.It sounds almost like the muffler is dragging on the ground.Have any of you guys had this happen before..i hope nothing is going bad
Old Jun 27, 2003 | 09:20 AM
94formulabz's Avatar
Is your muffler dragging? jk
Does this describe your problem :http://web.camaross.com/forums/showt...hreadid=137380
Or is it definitly from the back end?
I don't know if you have an m6 or not.
Old Jun 27, 2003 | 09:22 AM
Gripenfelter's Avatar
Any vibration at all?
You should get your rear checked out from a shop ASAP.
M6....LOL its not dragging
Old Jun 27, 2003 | 09:29 AM
Alittle vibration in the rear end but nothing like seat shaking
Old Jun 27, 2003 | 09:48 AM
loose u joints or torque arm bolts could cause a vib at takeoff that doesn't appear at speed. I've experienced them both, but thats more like a thunking sound than a muffler dragging sound. Maybe if something is loose it's the driveshaft is rubbing? If it was that loose though it would probably be a major vibration.
this is one of those really hard things to guess at based on just a short description.
Old Jun 27, 2003 | 10:24 AM
Tires_Smokin's Avatar
Check your tranny mount....
Old Jun 27, 2003 | 11:07 AM
RyanMacZ28's Avatar
How many miles are on your car? When was the last time you changed the rear diff oil? I had a similar problem, and when I changed my rear diff oil, it went away. Do that, then see if its still there.
AdsoYo
May 2, 2018 03:21 AM
NewsBot
Dec 21, 2014 06:55 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
