My Car Just Hit 100k
Well, the T/A just rolled over 100k miles this weekend. I know there are some services I need to have done to my car now that it has hit its 100k mark. What do I need to have done that is most important? I'm kinda broke right now, so I can't afford a BUNCH of stuff. But what is the most important thing I should have done?
Changing all your fluids and filters wouldn't be a bad idea. Check the belt and hoses for wear. Check the water pump and the other accessories. You know, all the general stuff you're supposed to keep an eye on when you have a car that no one ever does.
You could actually do some maintenance for cheap. Drain and refill M6 trans, only takes 3 quarts of ATF.. Dextron II if i remember correctly. Fuel filter $10.00. Rear diff change, fluid and sealer $15.00, Air filter if OEM set up $7.00, drain and refill coolant or a flush. Spark plugs $6.00 a piece for OEM Delco's at autozone. Wires not a bad ideal but if no miss-fire wouldnt mess with. Purchase 88 cent can of aerosol carb cleaner from wal-mart. clean throttle body and throttle blades with cleaner and rag and use rest of can to clean out PCV valve.
ChrisFrez
Dec 28, 2014 02:25 PM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
