My car is detonating, I need to fix it please help
Old Feb 16, 2007 | 02:39 PM
  #31
ELLOKOTE5's Avatar
I had a similar problem, except mine would detonate at WOT. The problem was wires 7 and 8 were bad, chaged them and problem solved.
Old Feb 16, 2007 | 08:20 PM
  #32
CamaroUK's Avatar
I'm not sure about camaros in the UK but the ones made for the US are designed to run only on super unleaded....
I understand the US and UK have different representations of octane ratings, the regular unleaded here is RON 95 and the super is around 97/8. I would assume the regular here is about the same as what it is in the US after you've converted the numbers.
The car always ran fine on the regular, but the super helped with the strange detonation problem once it set in. My car runs fine on the regular, i'd be amazed if sticking super in gave me any gains.
Old Feb 17, 2007 | 10:27 PM
  #33
DelSoto's Avatar
It finally threw a code today. 43. I went back and checked the voltage at the Knock sensor wire and it was fine....again. The knock module was a new one but untested. It failed the resistance test...ugh. Put another new one in and problem solved on the detonation issue. Thanks for the help fellas!
Old Feb 17, 2007 | 11:11 PM
  #34
JP95ZM6's Avatar
Excellent! The symptoms really sounded like no knock detection, so the solution fits perfectly. Glad you fixed it.
Originally Posted by JP95ZM6
Bad Knock Sensor? If it knocks and is not showing knock counts, sounds like the car can't hear the knock.
Old Feb 18, 2007 | 12:00 AM
  #35
DelSoto's Avatar
Thats what I first thought as well but after replacing the knock sensor I discounted it as being a possible prob until it threw a code and I decided to get the voltmeter out to double check. I have been driving it like this for 3 weeks now having to baby it around and today was the first time it threw that or any code. Now to iron out the 'other' prob it has when it gets hot and decides to sputter and pop out the exhaust and not want to rev over 1500-2000 rpm.
Jazsun
Dec 29, 2014 12:14 PM
Cam's maro
Dec 28, 2014 09:30 AM
USAirman93
Nov 24, 2014 03:37 PM
squarehead
Nov 21, 2014 08:02 PM
