My build thread. Few questions
Old Jun 20, 2011 | 02:31 PM
Camaro350z28's Avatar
Trying to wrap up the buying of parts for my build.
1995 M6 car.
LT1 stroked 383
what i have:
-forged eagle crank
-forged eagle hbeams
-forged srp pistons
http://www.ls1tech.com/forums/parts-...d-pistons.html
here is the first question. I dont really plan on spraying or boosting. these are the parts that came with my build. I was thinking i should switch to flat tops. Now how much power will this rob? its going to dump my compression some if i keep these dished. or maybe not depending on true numbers of my heads and gaskets i use?
-afr lt4 competition heads ported 195cc? i need to get heads checked i purchased them and seem to have lost the complete info
-lt4 intake
-bauer cam matched to my heads 240/240 on a 110
-ls7 lifters
-comp pro mags NSA 1.6 w/guide plates
-42lb injectors
-pacesetter longtubes, true dual 3" exhaust
what i dont have:
-58mm throttle body
-piston rings what rings should i go with? no plans on boost and i plan on getting flat tops
-clutch, competition stage 3 is planned
-push rods, waiting on measure
-tune will be done local
what else am i missing? im trying to get everything together so i can take block in and have it assembled. i know i dont have tons of info or all the technical numbers but i thought someone might be able to help a little
now this setup made 450rwhp im hoping to achieve right around the same. let me know how stupid i sound or maybe just some insight. thanks
Old Jun 20, 2011 | 06:10 PM
Kevin Blown 95 TA's Avatar
Re: My build thread. Few questions
A 383 compresses more air than a 350 so the pistons may be OK even if they are slightly dished. You need to verify the volume of your heads and then the volume of the dish of the pistons, and the deck height, and I assume 4.030 for hole dia., and and figure out your static compression ratio. You can alter this with your gasket choice some. Then have your cam grinder help you with dynamic compression calculations and figure out if it falls in the zone or not for that cam. If he tells you that it needs more static compression to get the right dynamic compression, then you will have to see what a gasket change or possibly new pistons will get you.
Old Jun 20, 2011 | 06:39 PM
ok thanks ill get this head info and still gotta get my block and everything into the shop
Old Jun 20, 2011 | 08:08 PM
210cc afrs with 61cc combustion chambers
Old Jun 20, 2011 | 09:51 PM
MachinistOne's Avatar
Those pistons will be fine, just have the heads milled some to bump the compression up - your machine shop can do the calculation for you. They also can supply a set of moly top rings to fit those pistons, you don't need anything special.
Old Jun 20, 2011 | 10:51 PM
sounds good... now ive been thinking about a shot of nos.. if i only hit it with like 100-150 later down the road will choosing rings for just NA be fine?
Old Jun 20, 2011 | 10:55 PM
actually just scratch that i really dont want nos ill talk to the builder
oldschool
Feb 9, 2016 09:21 PM
transam_388
Mar 15, 2015 11:53 AM
Moshbmx1
Jan 20, 2015 03:27 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
