My 95 Trans Am has OBDII?
I went to AAP today to scan my pcm to find that the connection was for an OBDII fitting. I am confused. I thought OBDII didn't start until 1996. Also, I got my pcm from a 94 z28? What the heck is going on here?
Re: My 95 Trans Am has OBDII?
To clarify.
All 94 Fbodies are OBD1
All 95 Fbodies are OBD1 BUT use a OBD2 port
All 96 and up Fbodies are OBD2
your 95 isnt a freak job or anything its just built differently lol. Dont be alarmed your 94 PCM will work jsut fine also.
95/96 was a lil change year for f-bodies. If I remember correctly, even the 02 sensors were changed from a flat connector to a square connector?
Originally Posted by disco192
Some late 95 california cars were OBD2. Not sure how common they were, but Ive heard of it.
TransAm9585 has the right info, but it should be clarified to say
95 LT1 f-bodies...
If you have a California emissions equipped car, it will have RPO code
NB6. It still won't matter. If it is a 1995 LT1 in an f-body, it's OBD-I.
Campbellb48
Jul 5, 2015 06:31 PM
