My 383 keeps dying =/
Old Jun 1, 2005 | 03:21 PM
  #16
96ZRDR's Avatar
Re: My 383 keeps dying =/
Must be different with 93's and 96'z. I have owned both.
There are nipples on a TB.
Top goes to a sensor, (I believe it is for EVAP, or a fuel vapor purge from the EVAP canister).
Middle is PCV, comes from the top of the passenger side valve cover.
Bottom is coolant, it is a cross over to heat up the Throttle body for cold weather.
I guess you are right.
Old Jun 1, 2005 | 03:24 PM
  #17
WS Sick's Avatar
Yes the small one is to the cannister evap solonoid, and the big one is crankcase ventilation, the PCV is on the drivers side.
Old Jun 1, 2005 | 10:50 PM
  #18
Pasky's Avatar
Replaced the ICM, still dies. Im smelling coolant being burned when it gets warmed up....
I think I have a head gasket leak . There is no coolant in the oil though.
Old Jun 2, 2005 | 05:31 AM
  #19
slopokrodrigez's Avatar
You said you have no spark when it heats up Yes? If that is the case, either use freeze spray to cool down the suspect component or wait till its cold and heat up the ignition components one piece at a time. You could also check the wires from the ICM to the coil for 12 volts DC and from the PCM to the ICM for 1-4 volts AC when it is cranked after the spark goes away.
Originally Posted by Pasky
It will behave normally when its cold (still ticks) but it idles fine but the car shakes pretty badly (warm and cold) and when its warmed up, the car will start jerking around and will eventually kill itself.
Don't understand why you say it idles fine, but shakes pretty bad. Doesn't that mean it idles bad, not fine??????? Did you check for a dead cylinder? Aside from having a dead cylinder, you could also be loosing spark when it gets hot.
If you think you have a bad head gasket that is leaking coolant into a cylinder, have you pulled any plugs to see which one????????
Does it seem to loose coolant when it sits? That is, does the level at the radiator go down even the vehicle is not used?
Old Jun 2, 2005 | 12:14 PM
  #20
Pasky's Avatar
Nope not losing coolant or overheating. I found the shaking problem, my dampener has the rubber grommet coming out of it, it is also making the clacking noise and its getting worse i need to replace that. I havn't pulled the plugs to check, im gonna wait for this weekend but I think im smelling the coolant being burned off something on the engine, its not at the exhaust, like something falling onto a header or something. I did spill a bunch the other day so their may be some just burning off. I need to replace that dampener asap.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
Bxlt1
Sep 29, 2015 03:18 PM
KYWes
Sep 26, 2015 08:49 AM
