my 224/230 passed emissions!
Old Jun 1, 2007 | 11:47 AM
black95z0122's Avatar
my 224/230 at 112 passed emissions. Just got back from the gas station. I live in massachusetts. Just wanted to post this incase anyone had worries about buying this cam. I passed. I have a 95 m6, jet hot longtube headers, and a carsound cat at the end of each collector. I think this might have helped. I also got a mail order tune from madz28.com.
Old Jun 1, 2007 | 11:50 AM
Dave1980's Avatar
cool where are you located?
what LSA on cam?
Old Jun 1, 2007 | 11:51 AM
i'm from winchester but i got it tested in woburn
its ground at 112
Old Jun 1, 2007 | 12:04 PM
ttop1986's Avatar
Thats good to know that cam will pass because I'm running stock cam with long tubes. I'm due for inspection in a few months. Do you have any pics of how your cats are set up? Right now I have a mini highflow cat after my ypipe, but I know this is not enough because the exhaust makes your eyes water a little. Your also only a couple towns over from me.
Old Jun 1, 2007 | 12:13 PM
Mortify's Avatar
I guess I'm lucky not to have emissions here, I would DIE at testing.
Old Jun 1, 2007 | 02:39 PM
2000GTP's Avatar
Congrats. I'm sure having the dual cats and a decent tune helped as well.
Old Jun 1, 2007 | 02:47 PM
buzz12586's Avatar
Mine passed in VA as well.
Old Jun 1, 2007 | 02:54 PM
SS MPSTR's Avatar
Can you guys post the results of the emission test? I'm curious to see where these set-ups ended up in measured ppm. Thanks.
Old Jun 1, 2007 | 04:20 PM
Wild1's Avatar
What were your numbers?
Did they run it on the rollers (1000 & 3000 RPM)?
Or did they use the IM240?
Old Jun 1, 2007 | 04:30 PM
chevy94c's Avatar
Nice
I live in mass. I didn't want to have it installed than have to take it out.
That's the cam I wanted to get.
Old Jun 1, 2007 | 07:09 PM
here are my results
******************************reading******limit
hc grams per mile**************00.56*********01.20
CO grams per mile**************001.33*******020.00
NOx grams per mile*************00.35********02.50
CO2 grams per mile*************509.33********NA
This test is done with hoses on the tail pipes and the car on rollers. I believe they take the car up to 30mph. I'm only guessing though because all i can do is watch it happen
I'm going to try and find my slip from before the cam/exaust/cats i believe that i might have done better after...wierd
I'm happy i passed but just because i passed doesn't mean you will. If it is your ride to work you might want to think about a cam..I was freaking out about this
Old Jun 1, 2007 | 07:21 PM
my results from the emissions test before cam/longtubes/new cats
(Same Tester/shop)
************************Reading**********limit
HC grams per mile*********00.87***********1.20
CO grams per mile*********004.84**********020.00
NOx grams per mile********01.31***********2.50
CO2 grams per mile*********510.94**********NA
Results from 4 years ago (Different shop/tester)
HC grams per mile*********00.74***********1.20
CO grams per mile*********001.12**********020.00
NOx grams per mile********02.02***********2.50
CO2 grams per mile*********411.79**********NA
Old Jun 1, 2007 | 08:08 PM
ricehammer's Avatar
Looking at the results -
Bigger Cam + New Cats = Cleaner Running Car
Nice job!!! Is that a COMP 503 your running? I gotta deal with emissions, but I also got "connections".
Old Jun 1, 2007 | 10:34 PM
Wild1's Avatar
Those are great numbers! And that is on a stock block, not a 383 right? Wow.
Old Jun 1, 2007 | 11:42 PM
224/230 = comp 503
stock bottom end... 78000 original miles
thanks
