Mufflex 4" and Global West Traclink... no good :(
Hey guys,
Worked some on the 96SS this weekend. Went to finish it up yesterday but was disappointed when the Mufflex 4" y-pipe (mates up with Hooker long tubes) would not anywhere near come close to fitting with the Global West Traclink kit I have on the car.
So, I have a couple options... go back to a stock torque arm or find an aftermarket one.
To go back to a stock torque arm I'm going to have to buy about $75 worth of "bracketry" and accessories because all mine has been removed and I don't have the old factory parts. But, before I spend this much money on factory stuff, I'd rather get an aftermarket item... if one exists.
I've done some searching here and see that Spohn supposedly made one about 6 months ago but when going to their site they only mention a version for the 3" Mufflex. It looks completely different than my setup and one unacceptable "feature" is that it goes UNDER the Mufflex y-pipe which currently is already the lowest point under the car. Having something going under this isn't going to work for me
Yesterday I test fitted the IRS torque arm too and it interferes in a different area. ARGGH!!!
Any ideas? Any company make one of these torque arms for 4" Mufflex guys?
Thanks!
Thanks!
You should go with a 3" true dual setup. The shop
that did my 2.5" did a 3" system a while back for
a guy with long tubes as well. The tricky part is that
you need to go over each side of the axle rather
than on the pass side. It takes adjustment of the
fuel lines. Just a thought.
Re: 4" and t.arm
Originally posted by Mike383LT1
you can try bmr fabrication there extreme line or madman's
the BMR Xtreme duty swaybar and trackpac both have xmembers that go under the 4" mufflex y Pipe. I have the Mufflex Y and the 4" transition is right above the BMR x member,but i believe it does sit slightly higher then the spohn.
Thanks for the info RacinLT1. I'll look into that one as well but ideally I'm trying to find one that does NOT go under the Mufflex. That just kills ground clearance if you know what I mean and I have to have at least one daily driver. LOL!
On a side note, I've found my old clamshell type torque arm tranny mount. It came in a box of "stock" stuff when I bought my 96SS (already had the Traclink installed). However, since I didn't take this off, I don't know what it should look like and the parts books don't show this in enough detail. My question is, if you look at the below picture you'll see that two of the mounting locations have rubber mounts... the third one... the one on the top and to the right in the picture, does not. I can't tell by looking at the tranny if there is supposed to be one or not? The area in the picture where there is no "dirt" is about the same size as where it would mount to on the tranny so can't tell if there is supposed to be a rubbing "washer" here as well or not? If you are familiar with this, please let me know asap as I'm out working on it now
thanks!
http://www.bfranker.badz28.com/misc/torquearmmount.jpg
thanks!http://www.bfranker.badz28.com/misc/torquearmmount.jpg
http://www.spohn.net/product.cfm?productid=1331\
This setup is made to work with a 4 inch mufflex and a 3 inch Muffley Y PIPE, and long tubes. It is what I have. They said it will work.
David
David
Thanks David! I've spoken to them today about that torque arm and it just sacrifices too much ground clearance for my everyday car
I have the stock torque arm installed right now so at least I can drive the car
Originally posted by JPSartre12
I've got a 4" exhaust system on my 94Z with a BMR torque arm and cross member, but the exhaust was custom made. It also has a Eibach drag launch kit and other goodies that keep it very low to the ground. My collectors are the first thing to hit (Hooker long tubes) on my 2" lowered front end.
I currently don't think the car will run faster than 10s in the 1/4 even after my upgrade plans so I should be good to go.
Thanks guys!
David
Originally posted by FASTFATBOY
What clearance, what area? I have the arm installed in the car now, no ex or engine though. looks fine from what I can see.
David
David
Brent, check out the wolfe racecraft arm. Definately a tough bar, and it goes above the exhaust.
http://www.wolferacecraft.com/images...arm/fbtq09.jpg
http://www.wolferacecraft.com/images...arm/fbtq31.jpg
http://www.wolferacecraft.com/images...arm/fbtq23.jpg
