Much HP diff. between 24 & 26 lb injectors?
Old Jun 4, 2005 | 07:00 PM
Randy L's Avatar
I just recieved my SVO 24 lb injectors and will be swapping out the stock 26lb ones in my '97 LT1. MadZ28 mentioned he flow tested the SVO's to push just over 25lbs instead of the rated 24.
I wonder if I will lose any performance or response between the stock 26lb'ers and the SVO 24lb'ers.
Though I am not 100% sure about the stock injectors for the '97 being 26lbs, this is what I have found on several parts sources on the internet.
Old Jun 4, 2005 | 07:06 PM
TobyZ28's Avatar
Re: Much HP diff. between 24 & 26 lb injectors?
Stock injectors are 24# (or 24.9# if you look at what the PCM is programmed as).
Going to a slightly smaller or bigger injector will not hurt performance at all, nor will it gain anything UNLESS your making a lot more then stock HP and the injectors are near their max duty cycles.
Ford 24# SVO's do push 24#'s at the fuel pressure ford cars use. However on the LT1, we have a slightly hihger fuel pressure, so the "ford" 24# injectors are going to be actually operating at a higher pressure, this means they will be putting out just around 25# of pressure as you mentioned above
Old Jun 5, 2005 | 02:07 AM
Randy L's Avatar
Cool, that's reassuring to hear. Just didn't want to sacrifice any performance by going to SVO 24lb'ers.
Old Jun 5, 2005 | 05:11 AM
Brent94Z's Avatar
Super Moderator
FWIW, I'm still running the stock 24# injectors in my 96SS which dynos 399 rwhp and runs 115mph trap speeds. Yes, I'm at the limit I believe If you aren't near those numbers then like toby360 mentioned, no worries
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
