To much cam lift???
Old Nov 6, 2007 | 07:39 PM
95 Civic's Avatar
To much cam lift???
I did a motor, tanny, and rear end swap. From my STOCK 94 z28 with a 4l60e and 2.73...
To a 94 Trans Am. I added a CAI, 1.6 roller rockers, hardened pushrods, Long tube pacesetters, intown built ORY, glasspack, TH350, 3.42's.
I swear my car is slower the way it is now... I dont understand...
One more question.. and let me know if it makes any sense...
I added 1.6 rockers to my stock cam, which added lift to my cam...
what is the STOCK lift for the STOCK springs...
Am i stressing my valvetrain...
thanks
Old Nov 6, 2007 | 08:05 PM
mdenz3's Avatar
Stock springs are barely able to handle a stock cam with 1.5 rockers.
The LT4 springs are cheap and will work good for a stock cam with 1.6 rockers.
Old Nov 6, 2007 | 08:09 PM
bufmatmuslepants's Avatar
might try a tune, mail order or dyno tune either one will help your computer get used to your mods.
Old Nov 6, 2007 | 08:18 PM
ws6_z28's Avatar
You are exceeding the max lift of the stock springs with 1.6 rr. Some people run them with no problems...but not others...
You ever come up to Little Rock? I was wonder if I have ever seen any of your cars?
Old Nov 6, 2007 | 08:19 PM
95 Civic's Avatar
I have 600 lift springs to go with the cc306... u think its just that?
Old Nov 6, 2007 | 08:33 PM
mdenz3's Avatar
So what is the exact valve train in the car right now?
Old Nov 6, 2007 | 10:02 PM
95 Civic's Avatar
car has comp cam hardened pushrods. 1.6 roller rockers. stock valve springs.
I have crane valve springs .600 lift im gettin ready to put on...
Old Nov 6, 2007 | 10:39 PM
mdenz3's Avatar
What camshaft?
Old Nov 7, 2007 | 12:32 AM
DrewHMS97SS's Avatar
That lift isnt going to fly with stock springs.
Old Nov 7, 2007 | 07:58 AM
95 Civic's Avatar
stock cam
Old Nov 7, 2007 | 10:43 AM
95 Civic's Avatar
ok, I did a little reserch, and tell me if I have wrong infor...
max lift for stock springs intake is 0.450
max lift for stock springs exhaust is 0.460
with 1.5 rocker arms intake its 0.447
and exhuast is 0.459
with 1.6 rocker arms intake its 0.476
and exhuast is 0.489
So what kind of trouble am I running into with having to much lift on these springs.... are my valves staying open to long or am I just stressing my springs...
thanks
kris
Old Nov 7, 2007 | 06:18 PM
joeSS97's Avatar
You are going to have spring coil bind.Not a good thing.It breaks springs,bends push rods,collapses lifters and ruins valve seals.On top of that your pcm will read a knock,retarding timing.Better take care of it.
Old Nov 7, 2007 | 06:29 PM
NemesisLT1's Avatar
so its prolly messing with your timing and making your car run stupid....
You need to get them other springs in there, and throw that cam in while your at it
Old Nov 7, 2007 | 07:00 PM
95 Civic's Avatar
car is parked.... cam is on the way.... springs will be installed.... car will be a hoss!
thanks so much guys...
kris
Old Nov 7, 2007 | 08:19 PM
'94 Bad A Z28's Avatar
TH-350 is why your car feels slower now, put a good 4L60E, I suggest a CPT trans, back in it and you'll be good.
