MT E/T street users...
Old Feb 9, 2004 | 11:47 PM
1984camaroz28's Avatar
Anyone out there running MT ET street tires... if so are you using a tube or u went tubeless. also is the Hoosier Quick time pro drag DOT tires tubeless......
Old Feb 10, 2004 | 12:30 AM
slp223's Avatar
I am using et streets with out tubes. they are more street able with out tubes. when you put tubes in them the get hotter just street driving.
Old Feb 10, 2004 | 01:18 AM
InjectedSS's Avatar
You dont need tubes unless you plan on running like 5psi
Old Feb 10, 2004 | 01:29 AM
Transamdriver's Avatar
No tubes here.
Old Feb 10, 2004 | 05:52 AM
maroon94z's Avatar
No tubes here either.
Old Feb 10, 2004 | 08:02 AM
O ok thanks
Old Feb 10, 2004 | 10:12 AM
fastcamz28's Avatar
Do any of you guys use wheel screws to secure the tire to the rim?
Old Feb 10, 2004 | 10:18 AM
OrionSPL's Avatar
No tubes or screws here. If you talk to M/T they will tell you that you need them. But it's not necessary.
Old Feb 10, 2004 | 10:29 AM
mongse_1's Avatar
I never ran tubes on my ET Streets and they were on the street all the time. I will be running tubes and screws on my new slicks though.
Old Feb 10, 2004 | 10:43 AM
Gripenfelter's Avatar
No screws. No tubes. 11-15 psi.
Old Feb 10, 2004 | 11:46 AM
n20ta2's Avatar
Im running screws but its not really nessasary unless youre really hooking hard,Last time at the track I got one wheel off the ground a couple inches.
Old Feb 10, 2004 | 12:05 PM
how hard of a hook befor u need screws
Old Feb 10, 2004 | 12:19 PM
If you're scraping the rear bumper on the ground you need screws.
Old Feb 10, 2004 | 01:00 PM
blkchevyz's Avatar
i would mark them to see if they move.
i was only pulling low 1.7s 60s and i was spinning them on the rim... that was with 15 psi of air.
Louey
Pacific
Oct 1, 2015 12:37 AM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
Louey
Pacific
Sep 1, 2015 07:19 PM
