MSG Ignition
Old May 29, 2003 | 10:29 AM
Green G0blin's Avatar
MSG Ignition
ok..here is my set up.
jet hot hooker long tube headers
true dual exhaust (dynomax bullets and x pipe)
port and polished heads
lt4 hot cam
2500 stall
port matched intake
3.73 gears
opbd1 conversion
NGK plugs
Taylor OTVC wires
do i need msd ignition? is it worth the extra $200 dollars??
Old May 29, 2003 | 10:31 AM
IrocManiac's Avatar
It'll probably help if it doesn't F up your opti. I personally wouldn't touch the ignition if its working good. Just leave it alone I've seen stock opti's last a long time and some crap out after 30k miles. Just leave it alone then if it breaks maybe add the MSD.
Old May 29, 2003 | 10:32 AM
94SLUG's Avatar
There coil makes a great paper weight! No stock ignition is fine and the MSD coil was the worst money ! ever spent, well than and AM FPR.
Old May 29, 2003 | 03:08 PM
Laymaster's Avatar
I thought an air foil was the worst money ever spent? =D
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Aaront810
Sep 11, 2015 11:24 AM
