MSD w/ Delteq? Will it be needed?
Old Apr 4, 2004 | 12:59 PM
SMOKNZ's Avatar
I currently run a MSD 6BTM (don't use the BTM part of it anymore) with a stock coil and Opti on my turbocharged Camaro. It works ok, but the stock system NEEDS the MSD to work right or it blows out the spark during boosted situations. I found this out at the track last year after I disconnected the MSD trying to rule it out as a problem in my ignition system (was the opti) Well I forgot to hook it up and my car was running about a second + slower than usual and I couldn't figure out why. I found the MSD disconnected and went back out and picked up the lost time. Anyway this leads me to my question. I will be upgrading to the Delteq stage 2 when it comes out. I currently have already purchased the Northstar coils and ignition module. Will this multi-coil setup be able to handle boost situations, or will the MSD still be required? Just wondering if anyone has come across this yet?
Bill
Old Apr 4, 2004 | 03:25 PM
Dave88LX's Avatar
I don't see why you'd need it, the coil packs take care of all that from what I understand.
I'm looking at getting the Delteq, who did you get the coil packs and ign module from?
Old Apr 4, 2004 | 03:58 PM
kmook's Avatar
Advanced Tech Moderator
http://delteq.com/support.htm
Things like MSD CD boxes will not work with the Delteq system.
Also transfering to LT1 Tech, thanks.
Old Apr 4, 2004 | 04:47 PM
Robs97Z28's Avatar
I beleive this is the box you will have to tun with the Delteq; MSD Digital DIS-4 - PN 6215
(Designed for use on 6 or 8-cylinder engines with three or four coil packs.)
when you order the box you will have to tell them you are running the northstar ignition.
I just installed the stage 1 on Saturday.
Old Apr 4, 2004 | 04:56 PM
Dave88LX's Avatar
Did you get your coil packs through Delteq or another source, and if so where and how much?
Old Apr 4, 2004 | 05:13 PM
SMOKNZ's Avatar
I got them off ebay, just do a search for Northstar coil
Bill
Old Apr 4, 2004 | 05:53 PM
Dave88LX's Avatar
Bill
Sweet thanks!
I need 4 coils and an ignition module right?
Is the ign module on this pic? Or is it just small and I don't see it...
http://i6.ebayimg.com/03/i/01/97/d0/8c_1.JPG
Old Apr 4, 2004 | 06:12 PM
Dave88LX's Avatar
Also, I assume you guys mounted it in the location they supply brackets for, down by the radiator?
Old Apr 4, 2004 | 06:32 PM
kmook's Avatar
I made a bracket out of sheetmetal, and custom mounted mine here:
http://community.webshots.com/photo/...29833547CyrIPu
Old Apr 4, 2004 | 07:01 PM
Dave88LX's Avatar
Are those Northstar coils?!?
Edit: Looks like you just turned them so they're all straight across instead
Old Apr 15, 2004 | 08:39 PM
Robs97Z28's Avatar
I bought the complete system from delteq. I thought this would be easier then trying to track them down myself. Plus they would be new, I would be less likely to have any trouble that way. Happy to say, it was flawless. First key of the key and she started.
I also talked to Pete about running MSD with this system. He said, it wasn't nessary.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Ari G
Dec 11, 2014 03:21 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
