MSD w/ Delteq? Will it be needed?
I currently run a MSD 6BTM (don't use the BTM part of it anymore) with a stock coil and Opti on my turbocharged Camaro. It works ok, but the stock system NEEDS the MSD to work right or it blows out the spark during boosted situations. I found this out at the track last year after I disconnected the MSD trying to rule it out as a problem in my ignition system (was the opti) Well I forgot to hook it up and my car was running about a second + slower than usual and I couldn't figure out why. I found the MSD disconnected and went back out and picked up the lost time. Anyway this leads me to my question. I will be upgrading to the Delteq stage 2 when it comes out. I currently have already purchased the Northstar coils and ignition module. Will this multi-coil setup be able to handle boost situations, or will the MSD still be required? Just wondering if anyone has come across this yet?
Bill
Bill
http://delteq.com/support.htm
Things like MSD CD boxes will not work with the Delteq system.
Also transfering to LT1 Tech, thanks.
I beleive this is the box you will have to tun with the Delteq; MSD Digital DIS-4 - PN 6215
(Designed for use on 6 or 8-cylinder engines with three or four coil packs.)
when you order the box you will have to tell them you are running the northstar ignition.
I just installed the stage 1 on Saturday.
Originally posted by SMOKNZ
I got them off ebay, just do a search for Northstar coil
Bill
Bill
I need 4 coils and an ignition module right?
Is the ign module on this pic? Or is it just small and I don't see it...
http://i6.ebayimg.com/03/i/01/97/d0/8c_1.JPG
Originally posted by Dave88LX
Also, I assume you guys mounted it in the location they supply brackets for, down by the radiator?
http://community.webshots.com/photo/...29833547CyrIPu
I bought the complete system from delteq. I thought this would be easier then trying to track them down myself. Plus they would be new, I would be less likely to have any trouble that way. Happy to say, it was flawless. First key of the key and she started.
I also talked to Pete about running MSD with this system. He said, it wasn't nessary.
