MSD Placement
Old Jun 17, 2003 | 01:15 PM
Black_Z28's Avatar
MSD Placement
Where are you guys putting your MSD ignition module? It would be great if you had pictures of where you put it. Thanks a lot.
Old Jun 17, 2003 | 01:30 PM
indy500ss's Avatar
I have the Crane HI-6S and a Moroso CAI, I mounted the ignition box right above the K&N. Right about where the stock airbox filter hole is. I do not have any pics but it was a real clean, simple, and invisible install. If you have CAI and your box is roughly 2x3x6 this should work. Good luck.
Old Jun 17, 2003 | 01:32 PM
FireAm94's Avatar
I put mine just in front of the strut tower on the drivers side...where it dips down. I think I barely had to move the fuel line bracket.
Joe
Old Jun 17, 2003 | 01:54 PM
IDOXLR8's Avatar
You can also mount one on the firewall. Sorry I have no pics.
Old Jun 17, 2003 | 01:56 PM
FireAm94's Avatar
Is it any easier to get to it to adjust?
Thanx
Joe
Old Jun 17, 2003 | 04:53 PM
Black_Z28's Avatar
I just checked, and it won't fit in that area.
Old Jun 17, 2003 | 11:51 PM
m0nk's Avatar
http://members.aol.com/atomicm0nk/car.html
2nd picture down
if you want a close up I could take on for ya
Old Jun 18, 2003 | 08:28 AM
Xscream's Avatar
I second monks mounting spot.. Cole if you need help I can always help you out with it. Otherwise you can see how if fits on my car.
Old Jun 18, 2003 | 12:10 PM
Black_Z28's Avatar
Sounds good Josh. I may have to take you up on that offer. But I have to replace my fuel pump first. I think it's on it's last leg.
m0nk- How did you secure the unit down? Sheet metal screws? And how long are they? Thanks a lot.
Old Jun 19, 2003 | 01:57 AM
m0nk's Avatar
Umm I would say the screws are about 1/4" after the bottom of the msd unit, only has 2 screws on the top R and top L, you can feel about 2 threads sticking out in the wheelwell
Old Jun 19, 2003 | 02:01 AM
madwolf's Avatar
Or you could mount it here.
Old Jun 19, 2003 | 12:41 PM
Black_Z28's Avatar
Do you have any better pictures of the unit? It's kind of hard to tell how you mounted it there. Or if you could tell me how you did. Thanks.
Old Jun 19, 2003 | 12:43 PM
madwolf's Avatar
No better pics, but it's mounted on top of the plastic mudshield, right near the CAI filter...
Old Sep 23, 2005 | 11:18 PM
DavesLT1's Avatar
Re: MSD Placement
I know this is a really old thread but I was looking at the placement areas here and the black cable that the wiring diagram says to go to the battery negative is too short, do I need to splice another length of cable (what gauge?) or can I just ground it to the chassis?
Old Sep 23, 2005 | 11:25 PM
Re: MSD Placement
You can easily ground it to the ground location by the headlights on top of the radiator support.
