MSD Placement
I have the Crane HI-6S and a Moroso CAI, I mounted the ignition box right above the K&N. Right about where the stock airbox filter hole is. I do not have any pics but it was a real clean, simple, and invisible install. If you have CAI and your box is roughly 2x3x6 this should work. Good luck.
http://members.aol.com/atomicm0nk/car.html
2nd picture down
if you want a close up I could take on for ya
2nd picture down
Originally posted by Xscream
I second monks mounting spot.. Cole if you need help I can always help you out with it. Otherwise you can see how if fits on my car.
m0nk- How did you secure the unit down? Sheet metal screws? And how long are they? Thanks a lot.
Thanks.
Re: MSD Placement
I know this is a really old thread but I was looking at the placement areas here and the black cable that the wiring diagram says to go to the battery negative is too short, do I need to splice another length of cable (what gauge?) or can I just ground it to the chassis?
Re: MSD Placement
