MSD opti LT1 Timing check
Old Sep 22, 2007 | 09:28 AM
drperformance's Avatar
I have reciently installed a MSD optispark on my 383 LT1 and want to double check my timing at the balancer since the MSD unit can be adjusted +/-7 degrees. Since I have a keyed ATI balancer with timing marks on it, when I installed my MSD opti I fabricated uo a timing pointer using a piston stop. Now when I check the timing at the crank I read about 27 degrees, about the same timing reading I see on the scanner.
Do I want to make the two timing readings match eachother? Or do I want to set the balancer timing to as close to zero as possable with the MSD opti? Is not the scanner reading ignition timing and I get cam timing on the balancer? I am thinking way to far into this and making my self confussed and need a second oppinion.
I just want to verify that the MSD unit is properly adjusted.
Old Sep 22, 2007 | 12:29 PM
The scanner is telling you how much advance (in crank degrees) the PCM is asking for, based on the timing tables. There is no feedback to tell the PCM where the spark is actually occuring. Your timing light flashing on your pointer (since the damper is on the crank) should match what the PCM is calling for. The PCM and the timing light value should match.
Old Sep 22, 2007 | 11:35 PM
mrmint69's Avatar
The only reason to adjust the timing on the Pro Billet MSD is for non stock cams i believe. To set it to factory setting you do something like screw it in all the way and back the setting screw 2 1/2 turns. I don't remember for sure so check your manual to be sure.
Old Sep 23, 2007 | 10:26 AM
If he has a timing light and a scanner, he is setting the MSD correctly. Why use a "hit or miss" count of screw turns, when he has the actual timing right in front of him. Helps when you have a correctly marked damper and a correctly installed pointer, which he appears to have.
Old Sep 23, 2007 | 11:32 AM
I would not rely on the turn of the screw to be accurate on the MSD unit, anyway.
Old Sep 23, 2007 | 11:39 AM
Its probably the worst thing MSD could have done.... makes no sense at all. Just another variable to get screwed up, unless you can check it with a set of timing marks and a light.
Old Sep 23, 2007 | 12:18 PM
The Engineer's Avatar
Here are some additional MSD timing adjustment issues to consider. When you add advance with the MSD Opti adjustment screw (screw CCW) an internal spring-loaded plunger is designed to push the optical module as the adjustment screw is backed-out. However, that plunger doesn’t always move the module, often it sticks (more often than not).
The only way to be sure the module has moved with the CCW adjustment, is to have the distributor open. I placed some reference marks on the housing (each side of the optical module) with a fine-point Sharpie then went from there with the timing.
I’ve played with the timing some on my MSD and added a few extra degrees of advance. That really picked-up the performance on my car. Almost a tenth in the quarter.
WD
Old Sep 23, 2007 | 03:22 PM
I have been using timing light and matched the timing that my scanner was reading @2000 rpm where the timing seemed to be more steady and easier to read. I agree and think that MSD should have never added this timing scew, its just added confussion and opertunity for mistakes. As you stated injuneer I also did not believe that the accuracy of 2.5 turns out would put me where I needed to be. So I fabed up a timing pointer and set it my self. If I remember correctly it ended up being out further then 2.5 turns.
Old Sep 23, 2007 | 11:10 PM
I did some work with the original version of the Electromotive SDI/Opti-Eliminator. To be sure I had the timing correct, I marked the toothed wheel that bolted to the stock crank hub with degree markings, and referenced it to the magnetic pickup, using a timing light. There was really no other way to do it. Currently, I use the Opti optical sensor to feed a MoTeC M48Pro ECU, and their 8-channel ignition driver. No way the system could be set up with any degree of confidence without an accurately place pointer and the degree marks on the ATI Super-Damper.
mr28
Apr 20, 2016 05:44 PM
*Emilia*
May 13, 2015 09:05 AM
thenewkid
Nov 27, 2014 09:41 AM
mr28
Nov 23, 2014 11:11 AM
danielbmx
Aug 27, 2002 11:11 PM
