MSD Opti: How much timing advance?
Old Jul 5, 2008 | 01:18 PM
  #16
C_Rules's Avatar
Originally Posted by my94blackz
Drive it. When I installed mine I made 10-12 passes with a rachet long extention and swivill in the car with me. I drove it till it felt right. When I put mine on it bogged at low rpm, kinda a hesitation, so I turned it then it started busting out on top. After 10-12 runs it was perfect.
thanks blackz. my only problem is that i use tuner cats and really want the timing I command to be the true timing of the vehicle. if i use the opti screw i'd never know what my timing is.
Old Jul 5, 2008 | 01:21 PM
  #17
C_Rules's Avatar
Originally Posted by shoebox
The only way to actually know what timing the MSD is giving the engine is to rig up a timing pointer, verify with a scanner the advance the computer is providing and then observe the advance on the pulley. That's a lot of trouble. Some have noted that the screw does not alway engage properly and that would definitely skew the intended amount of advance/retard. That is one of the things I don't like about the MSD.
shoebox is there a how to on your website for this? if not do you know where i can get a write up? i figure i can rig up the pointer easily when i get my engine back.
Old Jul 5, 2008 | 05:45 PM
  #18
my94blackz's Avatar
Set it the opti where it runs the best now, then tune it closer or tweak it with you computer.
Noenav
Mar 1, 2019 07:38 AM
Feffman
Oct 9, 2015 05:42 AM
nikolt1
Feb 27, 2015 09:10 PM
ScottZ
Mar 3, 2004 01:34 PM
