MSD ignition help
Old May 1, 2004 | 04:43 PM
cndctrdj's Avatar
MSD ignition help
hey all i just got the msd 6a box and decided to plug it into my car. well i did and nothing happens it just turns over and over and nothing. i have the blaster coil and helicore wires also but those have been in for months and never had trouble. i got the wiring harness and didn't have to cross any wires or anything. just have no idea what i did wrong i am gonna go over it again and see what happens, if any of you know anything about this please help ive had a bad day and am on my last nerve
Old May 1, 2004 | 05:08 PM
cndctrdj's Avatar
ok so i unplugged this thing and the car starts right up. i did some inspecting of the whole setup and i think i found the problem. i have no idea what im doing. is thier a big difference between the wireing harness for a 95 and a 96
or could it be that the belt is off the car and the alternator is not running
Old May 2, 2004 | 06:25 AM
schpenxel's Avatar
Is the MSD thing brand new or what? Is it grounded well? Power wire hooked up straight to the battery?
Old May 2, 2004 | 07:55 AM
The MSD harness is different between 95 and 96 because the coil is different. Why do you ask?
If you have it powered and grounded correctly, sounds like your unit is bad.
Old May 2, 2004 | 10:53 AM
cndctrdj's Avatar
it is grounded on the core support where other things are also grounded and the power is comming from the little power thing next to the battery
Old May 2, 2004 | 11:13 AM
schpenxel's Avatar
Possible the unit is bad then, there's a way to test it, somewhere on MSD's website. Has to do with grounding something to trigger a spark, so you can see if its sending an output signal or not. Look it up
Carson
Old May 2, 2004 | 11:37 AM
ABA383's Avatar
Which wiring kit did you buy? The 95 uses a dual connector coil while the 96 uses a single connector....make sure you have the correct wiring harness kit for a 95...I've got a 95 and the install directions out in the garage..lemme know if you need me to go get em...the 96 and 95 harnesses are not interchangable...
--Alan
Old May 2, 2004 | 03:05 PM
cndctrdj's Avatar
i have the wiring harness kit pn 8876 it is for a 95
i have the msd blaster coil can't remember pn
no its not wired directly to the battery but it is getting juice. i have it grounded to a spot where thier are other things, that work, are grouded to. the coil has 4 pronged inputs and one output. the wirieng harness that the car plugs into has only one prong going into the coil im pretty sure thats where the problem is. but everything worked before i put on the msd 6a box.
Old May 2, 2004 | 04:11 PM
ABA383's Avatar
Its only supposed to plug into 2 of the 4 connections on the coil..95s have a dual connector coil, but with the MSD you only use 2...I'll have to look at mine to see which pair...
Old May 2, 2004 | 08:17 PM
cndctrdj's Avatar
if you look at the connector that goes onto the coil thier is only one prong where thier is space for two and the plug that it replaces has two going into the coil
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
