MSD Coil Pack Bad?
Old May 10, 2004 | 11:42 PM
Canadian z28's Avatar
MSD Coil Pack Bad?
I was told that an MSD coil pack (the MSD blaster) which is a stock replacement for the car, is bad for it, is this true? should I have just bought a stock one from GM?
Old May 11, 2004 | 06:20 PM
Anyone know anything on this?
Old May 11, 2004 | 06:26 PM
ibanez6rg's Avatar
You were told wrong.
Old May 11, 2004 | 06:38 PM
Nothing "bad" about the MSD.
Old May 11, 2004 | 09:51 PM
Are they the same as the stock one?
Old May 11, 2004 | 09:54 PM
It is a higher output coil.
Old May 11, 2004 | 11:12 PM
Since it's a higher output coil would that not cause a problem? Poissibly with the Opti, wires or plugs?
Old May 11, 2004 | 11:19 PM
No
Old May 12, 2004 | 09:12 AM
Eff's Avatar
Eff
I think what your friend was refering too was EMF. However the protective measures taken for just about any plug wires (short of solid core) out there is more than enough for a blaster coil. To be honest. even if it was a problem. it would be a wiring problem. Not the coil.
Old May 12, 2004 | 12:42 PM
Thanks for answering the question guys, you saved me buying another one, when this one is working perfectly fine.
Old May 20, 2004 | 08:22 AM
Eff's Avatar
Eff
Glad we could help
Old May 20, 2004 | 08:27 AM
93redbird's Avatar
did you notice a difference between the stock coil and the msd? Throttle response, acceleration, anything like that.
Tim
Old May 20, 2004 | 10:03 AM
Tim
Can't remember, I put the MSD one on over a year ago, Plus i was pretty sure that the stock one was toast
Old May 20, 2004 | 10:22 AM
350 HRSS's Avatar
I installed one of those GM Blaster coils along w/ my MSD 6A. I have had no problems since, and that was over 3 years ago. This
is a heavily modded heads/cam car, and still, no problems.
Old May 20, 2004 | 10:05 PM
Eliminator's Avatar
does that mean it will make the car run better?
