MSD cap and rotor kit...DEAD!
Old May 31, 2006 | 01:38 AM
OneFlyn95z28's Avatar
Yes after 1,200 miles DEAD! Confirmed kill in pic below. same exact Ignition that kills Stock caps in 12-14k miles killed the MSD in 1,200
Current settings
MSD Cap and Rotor DOA
MSD Coil
16 year old(I kidd you not) MSD 6T with soft touch
NGK TR6 gapped to .040
EDIT
TO clear up what you are looking at. the black mark on the rotor is NOT supposed to be there. it is a carbon burn clean through the rotor. as dead short to ground when the ignition is trying to fire. The OPTI it self is fine and working great. LOTS of Spark going into the cap but not a damn thing coming out
Old May 31, 2006 | 05:37 AM
Heatmaker's Avatar
Advanced Member
Re: MSD cap and rotor kit...DEAD!
could you get some pictures of the inside please?
Old May 31, 2006 | 05:40 AM
Mtrhds94Z's Avatar
I'd sure be calling MSD on that one.. [warranty is a year isn't it?]
Old May 31, 2006 | 06:56 AM
Kevin Blown 95 TA's Avatar
Damn, I don't like that at all. Please keep us posted on what they find. I'm hoping that was some kind of manufacturing defect, because if MSD doesn't know how to make a distributor, then who does?
Old May 31, 2006 | 07:09 AM
wrd1972's Avatar
Closeup shots please.
Old May 31, 2006 | 07:43 AM
EVERESTZ28's Avatar
just talking about cap and rotor kit, why MSD is diferent form SUMMIT brand or just a kit from Autozone?
I just install a Summit and work great i don't know how long time i have been with a damaged cap, but after change i nottice like a recovery of 50hp.
Old May 31, 2006 | 09:12 AM
Honda Hunter's Avatar
50hp?
Old May 31, 2006 | 09:27 AM
That is about as close up as I could get. I will try again tonight. The Cap it self seems fine. early signs of carbon on the posts like a stock unit but they are brass so they are not melting.
I will be contacting MSD shortly
BTW I like how there are three Sales links for MSD across the bottom of the post here
Old May 31, 2006 | 09:37 AM
EVERESTZ28's Avatar
Originally Posted by Honda Hunter
50hp?
I'M not saying that i gained hp, it's only that i havent noticed that i was not burning well the gas and i was loosing power with the opti in bad shape.
Old May 31, 2006 | 09:38 AM
I just got off the Phone with MSD and they are being very helpfull as I expected.
Old May 31, 2006 | 09:53 AM
Gripenfelter's Avatar
That sucks. Looks like I'll be doing LTCC or Delteq as well then.
Old May 31, 2006 | 10:24 AM
Loadre's Avatar
LTCC for the winnar!
Old May 31, 2006 | 12:46 PM
1racerdude's Avatar
Ya got some high resistance somewhere causing the spark to come back to the opti. Plug wires,plug gap,plugs. It doesn't matter if they are new.
When ya increase resistance it is harder to fire the plug and it lets the spark back up in the opti and do just what ya see. Spark will take the path of least resistance.
Old May 31, 2006 | 02:31 PM
Hmm... never been a problem before?
I will measure them tonight and see
Old May 31, 2006 | 07:11 PM
LT4POWR's Avatar
Be sure and keep us posted. I was really hoping these would be the cure
