MSD 6AL ignition box install instructions
I have a 94 LT1 with an accel dfi stand alone. I need vivid instructions to connecting the box to the coil harness. There is a + grey connector and a - black connector on the harness that plugs into the coil. I already have the + and - connections to power the box I just need to know where the white, red, orange and black wires coming from the box connect into the harness. on the grey and black connectors there is a pink and white wire on both. I know the red and white wires go to the + and the orange and black go to the negative side. Just need to know the sequence.
Thanks so much,
Mark Tisdale
Thanks so much,
Mark Tisdale
Re: MSD 6AL ignition box install instructions
There are detailed instructions available on MSDs website. The easiest (and best, IMO) way is to buy an MSD harness that is plug and play. Good for installation and troubleshooting purposes.
Yea I was thinking the same, and also I didn't want to get a bad connection from me doing the wiring sometimes lol...
