MSD 6AL and Blaster Coil
Old Sep 20, 2006 | 10:07 AM
nodnarb481's Avatar
If i were to get these for my 95 trans am what would i benefit? ARe they worth the money? Any info would be nice.
Old Sep 20, 2006 | 01:48 PM
Ultra_Dog's Avatar
Re: MSD 6AL and Blaster Coil
Let's see...
MSD 6AL runs about $150, the coil, another ~$40.
Net gain> between zero and about 3# of torque between 1000 and 4500 RPM.
Problems solved? None, if nothing was wrong with your ignition coil anyway.
Opportunity lost: about five tanks of gas.
I'm sure others will claim that their LT1 went from 14.6 sec in the 1/4 to just a hair under 13.1 with this mod, but then this website is composed of hundreds of boastful individuals and dozens of retailers looking for another sucker.
Old Sep 20, 2006 | 02:27 PM
nodnarb481's Avatar
alrighty thanks.. i was thinking about just getting the coil if i feel like it.. where does the loss of five tanks come from?
Old Sep 20, 2006 | 03:16 PM
Bersaglieri's Avatar
I wouldnt waste money on it until you have a power adder.
-Dustin-
Old Sep 20, 2006 | 04:01 PM
jsetzer's Avatar
Price of gas, you could fill up severl time for the $200 wasted.
On that note I think regular is below $2.10 here now.
Old Sep 20, 2006 | 04:09 PM
nodnarb481's Avatar
o well i wasnt really thinking of getting the 6al i was just asking what it does.. if i get anything ill get the blaster coil because its cheap and i figured it could only help.. so i guess i could rephrase my question to.. is there any difference between switching from a stock coil to an MSD?
Old Sep 20, 2006 | 05:03 PM
I'm sure there are differences, but unless its broke I wouldnt replace the coil.
-Dustin-
Old Sep 20, 2006 | 05:28 PM
nick3's Avatar
there is not a big difference unless you have nitrous, turbo, supercharger or a 383. its helps to burn the added fuel for better combustion.
Old Sep 20, 2006 | 06:50 PM
396D1SS's Avatar
its a must must juice
Old Sep 20, 2006 | 09:06 PM
93 camaro z28's Avatar
i did both my msd 6al and my blaster coil at once and it made a huge difference on mine. but im pretty sure my old coil was bad cuz it ran rough and it missed. the best part about the 6al is when you decided to get rid of the stock rev limiter, you can adjust your limiter to whatever you want it to be.
Old Sep 21, 2006 | 10:05 AM
mzgp5x's Avatar
I went with the 6A + 8202 coil due to the ATI D1 mod. Then I had problems with the opti. The added juice caused alot of heat down there and the rotors were failing. Since then I think I have solved my opti failure problem (Its not broke anymore, I had to modify). Then, plugs (ngk) were fowling. I went with the zex plug and I have not had a problem since - I really like their plug. I like the MSD 6A (6AL), but, I don't think opti was built for it (I've been thru 4 of them). (1997 383 D1/ 72# injectors.) It's a trial and error sport with these things.
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
tdigger9899
Sep 7, 2015 10:56 AM
canuck94z28
Aug 19, 2015 05:50 PM
88IROC_Z
Jul 22, 2015 11:38 PM
