MSD-6A Ignition
Old Mar 27, 2005 | 08:35 AM
kicksZ28's Avatar
MSD-6A Ignition
How well do these work on a 95Z and will it work with ACCEL 9000 plug wires?
Old Mar 27, 2005 | 08:57 AM
94zgreenmachine's Avatar
Re: MSD-6A Ignition
I know the rev limiter worked well as I bounced it many times. The hardest thing is deciding where to put it in an already cramped bay.
Old Mar 27, 2005 | 10:18 AM
fastbird96's Avatar
Re: MSD-6A Ignition
The 6A doesn't have a rev limiter, the 6AL has one.
I don't think you'll notice any difference after installing one. I have a 6AL on my car just to have an adj. rev limiter. Unless you can get a REALLY good deal on one I think you would be better off to spend the money on something else. My .02
Old Mar 27, 2005 | 10:22 AM
Re: MSD-6A Ignition
Originally Posted by fastbird96
The 6A doesn't have a rev limiter, the 6AL has one....
Oops. Thats what I meant
Old Mar 27, 2005 | 12:53 PM
fearnside5's Avatar
Re: MSD-6A Ignition
where did you mount it? very little free space under the hood. any problems like radio interference , idle issues with stock injectors and ect. ?
Old Mar 27, 2005 | 01:44 PM
Re: MSD-6A Ignition
I didn't have any problems mounting it or with it working. I mounted mine where the fuses are. (below the fuel line on the fender, next to the intake tube) I pulled it out of the clip and gently turn it around and placed it below the clip. In its place I mounted the 6AL box. The only wire I had to extaend was the positive wire.
Old Mar 27, 2005 | 02:58 PM
69z-28's Avatar
Re: MSD-6A Ignition
i talked to someone who put in the 6a box, blaster coil, and harness, and he said it made a huge difference in the way the car ran, it was smooth and the throttle response was incredible he said.
Old Mar 27, 2005 | 03:08 PM
FryedClutch's Avatar
Re: MSD-6A Ignition
i think the msd is a great mod it was one of the first i did and before it i could only chirp second with the nittos but after words i could chirp third and really get second goin so i thought it was great i also did blaster coil and plugs and wires at the same time but they got er dun
Old Mar 27, 2005 | 05:05 PM
country_3030's Avatar
Re: MSD-6A Ignition
Has anyone used other ignitions like the mallory or crane?
Old Mar 27, 2005 | 06:22 PM
fastbird96's Avatar
Re: MSD-6A Ignition
I mounted mine between the fuse box and the fuel lines.
I did notice a smoother idle with the msd ignition but that's about it. Next time I get on the dyno I'm going to do runs with and without it hooked up and see what the difference is.
93 RedBird
Nov 15, 2015 08:24 AM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
tommalcolm
Sep 11, 2015 03:39 PM
Aaront810
Sep 11, 2015 11:24 AM
