Mr. Gasket head gaskets (.026")
Old Feb 26, 2004 | 02:21 PM
simple's Avatar
anyone think there will be any P to V clearance issues using those gaskets with stock heads that have been milled .010" and 2.00/1.56 valves and a stock bottom end
i'm not sure exactly what the lift will be on the cam yet, i'm in the process of having a custom cam done
reading up on quench area i think those gaskets will put me right into the ideal (?) amount of ~.051" quench
Steve
Old Mar 2, 2004 | 03:44 AM
simple's Avatar
anyone? TTT
Old Mar 2, 2004 | 06:06 AM
RE AND CHERYL's Avatar
Your squelch area will depend mostly on how far down the pistons are in the hole. If the bottom end is stock, they can be down quite a bit. In this case even a thin gasket won't help you.
But on your original question, the LT1 from GM is a non-interferance engine. This gives you a ton of piston to valve clearance for even radical cams. If your worried, mock it up with light springs and clay on the piston. Rotate the engine trrough a cycle and measure your clay. Unless your going nuts on your cam you shouldn't have a problem.
Old Mar 2, 2004 | 07:39 AM
toddlsf's Avatar
I ran a CC306 with that gasket and heads milled more than that with no problems. The thing you need to worry about is not really the lift, but the duration. That is where you might run into interference.
Todd
Old Mar 2, 2004 | 08:14 AM
4DRSS's Avatar
I'm also using these gaskets with aluminum LT1 heads milled .030" and a CC306. No problems whatsoever.
Old Mar 2, 2004 | 08:18 AM
simple's Avatar
thanks guys! looks like i'm gonna use them
where did you all order them from? Summit?
Old Mar 2, 2004 | 08:30 AM
simple's Avatar
just for clarification, this is the correct part number for that gasket...... P# MRG-5716?
Old Mar 2, 2004 | 09:52 AM
toddlsf's Avatar
I would use those gaskets as long as you are going N/A. I had a little trouble with them with Nitrous. But, the problem may have not been the gaskets.
Todd
FredM
Mar 6, 2015 03:04 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
