Mpg
Old Aug 25, 2009 | 07:47 PM
SmokeyBlaZe's Avatar
Mpg
How many mpg should I expect to get with my car and 2.73 gears, Mods in sig, thanks
Old Aug 26, 2009 | 01:03 PM
Maverick_997's Avatar
i would expect around 14-17 city and 19-22 freeway depending if you keep your foot out of it
Old Aug 26, 2009 | 07:45 PM
pearlpurple's Avatar
My car has 2.73 gearing,
I have gotten as good as 27 mpg strictly highway and nice smooth interstate, yes many will not believe me but I have checked this numerous times,,, I love my car.
Combined I usually get around 19 to 21 mpg if I don't get into it every light and stop.
Old Aug 26, 2009 | 09:15 PM
Nice , I was thinking around 17 , My mechanic said I would be lucky to get 8 mpg but the dumbass also didnt bother to ask what kind of gears were in it, on another note I just got it out of the shop and paid $250 to have the pickup tube put on along with a retainer bracket to hold it on and an 02 sensor replaced, An hour later I noticed that My oil psi is still dropping below zero at redlights and when I put it in reverse.. Taking it back up there tomorrow and I'm sure he is going to say that It's because my oil pump needs replaced but how is my oil pump bad if while driving the car has 70 psi.. I'm pissed to say the least..
Old Aug 28, 2009 | 10:26 PM
Talked to the mechanic today and he said it was probably the sending unit , so I changed it out and the oil pressure still sometimes drops to zero, I don't think I'm actually getting zero oil pressure because the valves dont tick or anything. Im getting a code 33 but I doubt that would have anything to do with it. Could It be because there is a high volume oil pump?
Old Aug 29, 2009 | 12:35 AM
Sk8phreak88's Avatar
27mpg with 2.73's?! I pull 25's easy strictly highway with my 3.42's I can usually pull 27.5 at 1600rpm. I can't go lower then 1600RPM's otherwise I get baddd cam surge.
EDIT: Didn't notice most of you guys are A4 guys.. M6 For the win!!
Old Aug 29, 2009 | 05:02 PM
slo bird95's Avatar
my 95 gets a combined about 12 mpg but the tune is really messed it. But id say a well tuned one would get about 18 combined
Old Aug 29, 2009 | 08:15 PM
The_Bishop's Avatar
I get about 19-20 with an A4 and 4.10 gears, mostly highway.
Aug 24, 2015 06:41 AM
Magenta_Hearts
Mar 22, 2015 03:36 PM
grgguy
17
Feb 23, 2015 07:57 PM
Meccadeth
Dec 14, 2002 08:37 PM
Willy boy
Jun 8, 2002 02:37 PM
