Mounting Y-Pipe?
Mounting Y-Pipe?
I have my y-pipe fitted in after my longtubes but the mounting holes dont line up w/ the stock oem mounts, do i even have to mount the y-pipe, it seems pretty solid off the headers and once i get my cat back in it should be fine? How did you guys do this??
Zach
Zach
Re: Mounting Y-Pipe?
Not exactly sure what your problem is, but the Y-pipes off of LT's usually run the end of the y right into the driveshaft tunnel. If you are thinking that the catback will bolt right up you are mistaken. You'll have to cut and weld/clamp your catback. Is that what you are trying to figure out?
-Dustin-
-Dustin-
where the cat back bolts to those two holes up by the tail end of the transmission, that is where the back of my y-pipe is supposed to bolt up to but the holes are off by a little over an inch or so.
Zach
Zach
I have the same problem with mine. I left it hang for a while but its starting to rattle on the tunnel support. I'm just gonna have the muffler shop put a couple hangers on it.
alliance12364
Sep 23, 2015 12:40 PM
alliance12364
Sep 23, 2015 06:09 AM
