Motor and tranny are in!!!!! Lots of Progress!!! PICS
For the guys that don't make it over to LS1 Tech:
Buttoned up the brake lines, plugs, wires and some other misc. stuff. Oh yeah, the motor and tranny are in! Couldn't have been done w/o Tony and of course Jeff at Maxwell. There's still a few things to finish but we may start it up sometime this week or next weekend.
1. Brake lines with SJM ABS delete kit
2. MSD Coil & Wires
3. Fikse's
4. Ready for a motor! Let's go....
5. K-member down, motor on.
6. Coming down
7. And she's in!
8. Finished product (almost)
2. MSD Coil & Wires
3. Fikse's
6. Coming down
7. And she's in!
Engine was built by Port Pros in Austin, TX. They also did the port work on the heads. I believe they flow right around 290 at .650" lift. Most of this stuff is on my FQuick site.
Port Pros LT1 383 Stroker
Wiseco Pro-Tru Forged Pistons
Callies Splayed Main Caps
Port Pros Stage II LT1 Heads (Competition 5-Angle Valve Job w/ 2.02-1.57 Valves)
Comp Hi-Tech Pro-Magnum Roller Rockers 7/16" stud, 1.7 ratio
ARP 7/16" Rocker Arm Studs
GMPP Guide plates
Comp R Lifters
ARP Head Bolts
GM Extreme Duty Timing Set
Oversized Crank Sprocket
K&N FIPK Cold Air Kit
Ford SVO 42# Fuel Injectors
Hooker Ceramic Longtube Headers
Mufflex y-pipe
Magnaflow catback exhaust system
This car is my hobby car and will mainly be for street/strip and some shows.
