Motor SHake after OPTI install
Old Jun 7, 2006 | 03:38 PM
hozb817's Avatar
I installed new OPTI and now motor shakes pretty bad, someone told me it may be timing/retard? any suggestions??
Old Jun 7, 2006 | 03:41 PM
StephenDeli22's Avatar
Re: Motor SHake after OPTI install
Did you make sure you got the opti on the car the right way? Are all the plug wires on the opti terminals? All wires on the plugs, ect. I would put money on it you put the opti on wrong though.
Old Jun 7, 2006 | 03:42 PM
blkchevyz's Avatar
probably crossed a wires. go double check them. and make sure they are all the way on
Old Jun 7, 2006 | 03:44 PM
hozb817's Avatar
Opti was definatly installed correctly, will look into the wires but they are numbered, any other suggestions?
Old Jun 7, 2006 | 03:50 PM
blkchevyz's Avatar
what was it doing before you changed the opti?
just make sure you hooked everything back up... check the wires to the maf, make sure the elbow is on all the way and isnt tucked into the throttle body
Javier97Z28's Avatar
Moderator
Sounds like crossed wires to me.
HectorM52
Jul 30, 2017 11:46 AM
Alex Barnes
Jan 24, 2015 10:21 PM
jermaine_rashad
Advanced Tech
Jan 4, 2015 02:32 PM
