Motor R&R Video...
Old Jul 6, 2008 | 11:59 AM
  #31
camzaro28's Avatar
This is awesome. Many CZer's and future/current LT1 owners owe you a big one for this.
Great job man.
Old Jul 9, 2008 | 10:04 AM
  #32
EaC95Z28's Avatar
yea man this is sweet. never had a chance to pull my motor or work on it in anyway this would be great to learn and see how its done right. thanks man.
Old Jul 9, 2008 | 10:22 AM
  #33
Connexion2005's Avatar
No problem. I'm working on the bottom end of the motor today and tomorrow and I should have my whole project done by the weekend hopefully...
Old Jul 11, 2008 | 10:19 AM
  #34
Ok guys chugging along. Here is the clip for how to set your crank in a fresh bottom end...
Old Jul 14, 2008 | 03:07 PM
  #35
Another clip guys...how to check crankshaft runout...
Old Jul 14, 2008 | 03:09 PM
  #36
ENRKyle20's Avatar
damn, your project is moving along faster than mine and you taped it!.. did you have the block in a machine shop?... that held me up for more than a month.
Old Jul 14, 2008 | 03:15 PM
  #37
I was lucky enough to pick the block up off a friend with .030 bored over and new freeze plugs and cam bearings. I got it and a full dissassembled lt1 for $300 which was impossible to pass up. So I used the money saved and went stroker...tonight will be a very late night and I anticipate to be putting it all back together in the next few days. I'm still waiting on my valvesprings to get here....
Old Jul 14, 2008 | 03:16 PM
  #38
ENRKyle20's Avatar
lucky bastard. a block that clean for $300.. with those things.. I paid more than that for cleaning, bore, hone, and deck. grrr.. You going to deck it?..
Old Jul 14, 2008 | 03:42 PM
  #39
Not gonna deck it. The pistons are already .005 from deck height and the heads were milled about .010 so no need. Compression will be near 11.7:1....
Old Jul 14, 2008 | 10:07 PM
  #40
Savannah Dan's Avatar
Not the video I was hoping for..............
Old Jul 14, 2008 | 11:49 PM
  #41
What exactly are you looking for Dan? Just let me know I really do appreciate feedback. Keep in mind this is just one clip out of around 300 in the video. I'm sorry but I am limited to my 5 megapixel camera right now but there is no reason anyone can not clearly see and hear what is going on.
Old Jul 14, 2008 | 11:51 PM
  #42
Completely assembled bottom end (383 Stroker)... Finally got all of the tons of clearances and tolerances measured and check as well as piston ring gaps.
Old Jul 15, 2008 | 11:56 AM
  #43
Keeping you guys updated here with a piston ring gapping clip... This whole film will be head to toe with no question in between.
Old Jul 15, 2008 | 12:47 PM
  #44
ENRKyle20's Avatar
Tighter on the lower ring????
Old Jul 15, 2008 | 01:43 PM
  #45
That was interesting to me as well but that is what they recommend. Apparently the KB pistons make more power which generates a lot more heat around the top ring thus why it must be gapped higher. Here is the article. I also mention to check with your manufacturer as that is the best way to be sure. I wouldn't take anyones word on the ring gapping except for the manufacturer...
http://kb-silvolite.com/article.php?action=read&A_id=32
