Motor pix check it out
Old Nov 9, 2007 | 10:38 PM
jclark311's Avatar
Just trying to see if i can send a pix via Photobucket. Forged 355 LT1
6 inch Forged Scat Rods, Mahle Power Pack, LE2 Heads/Cam, Trickflow pushrods/guides, Comp Cams NSA 1.6 Roller Rockers, GM Roller Lifters, Melling Select SV Oil Pump/GM White Spring, Fluid Damper, Meziere EWP, Delphi 37 lb injectors, Canton LT1 Valve Covers. Hows it look?
http://i222.photobucket.com/albums/d...s/P1010010.jpg
Old Nov 9, 2007 | 10:39 PM
jclark311's Avatar
I guess the pix link worked!
Old Nov 9, 2007 | 10:40 PM
95 Civic's Avatar
man... congrats to a good lookin motor!
Old Nov 9, 2007 | 10:51 PM
jclark311's Avatar
Thanks, i think it was harder to post a photo on CZ28 ,than to build the motor.
Old Nov 9, 2007 | 11:05 PM
Bow94z's Avatar
I bet ur excited to fire her up..
Old Nov 10, 2007 | 10:58 AM
jclark311's Avatar
Yea i am going to put it in this week, i took off work, i was hoping for better weather, i have a small garage, and will have to do some work outside.
Old Nov 10, 2007 | 11:38 AM
aboatguy's Avatar
Nice looking engine. Sounds almost like my combo. Good luck with the install.
Old Nov 10, 2007 | 08:40 PM
jclark311's Avatar
How did you get the pix in your post?
Old Nov 11, 2007 | 08:33 AM
2000GTP's Avatar
You need to click on the "insert image icon" which has the mountains and the sun. Then you will be prompted for the url link of the picture, which you have on the photobucket account.
Old Nov 11, 2007 | 09:22 AM
FASTFATBOY's Avatar
Nice looking piece!
Mock up your alternator, sometimes I have read those Canton valvecovers do not fit behind the alt.
David
Old Nov 11, 2007 | 10:21 AM
Projectcam94's Avatar
Looks real nicee
Old Nov 11, 2007 | 11:36 AM
jclark311's Avatar
Yea i was going to mock up the alternater, before i put the motor in, i heard the same thing, i might have to clearance the alternater a bit. Here is another pic.
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
newby
10
Jul 27, 2002 11:39 AM
