Motor Oil question!!
Old Jul 30, 2008 | 09:24 PM
BMD18's Avatar
Hi i am about to change my motor oil and i am wanting to put some good oil in it! I heard about royal purple and i am wanting to know if anyone knows whats in it like what are some of its qualitys. Also on my oil cap where you put the oil in it says SAE 5W30 but my dad has always put in 10W30 and he said he does that because it has a lot of miles on it so should i stick with the 10W30 or go with the gm recommendation??? Also would it be ok to put in Lucas oil Stabalizer with the royal purple or does royal purple have there owen stabalizer????????
Thank you !!
Old Jul 30, 2008 | 09:32 PM
camarozz95's Avatar
after alot of research around here I found that alot of people like the german castrol 0w 30 so I went with that and its been great. other wise before that I was just using penzoil 10w 30. The royal purple should be good too, but I would stay away from oil stabilzers.
Old Jul 31, 2008 | 07:44 AM
DAVE00's Avatar
I use and love Mobil 1 Synth (15W-50) as I have a little looser bearing tolerances on my 383 and need the thinker stuff.
Old Jul 31, 2008 | 08:41 AM
The_Bishop's Avatar
Run away from *any* oil additives. They are *all* junk.
Old Jul 31, 2008 | 09:21 AM
irocbsa's Avatar
Yep. If they could really deliver on all of the outrageous wear and fuel economy gains, don't you think the OEMs would be using them by now?
Stick with either Mobil 1, Royal Purple, or Amsoil and you'll be in great shape.
Old Jul 31, 2008 | 09:26 AM
JoeliusZ28's Avatar
M1 0w-40 i have read is good for LT1s
Old Jul 31, 2008 | 10:09 AM
maverickmk's Avatar
use the search feature - this has been discussed ad nauseum
Old Jul 31, 2008 | 11:57 AM
NukeFPE's Avatar
Read your owners manual
Old Jul 31, 2008 | 12:11 PM
PHATOM LT1's Avatar
I used the 5-30w recomended byt the factory but after I did the oil change my low oil light stayed on until I did my next oil changed which I used the 10-30w and never saw the light again.
Old Jul 31, 2008 | 12:39 PM
83tpi_3rd-gen(sri)'s Avatar
i use the cheapest advanced auto parts brand oil and my stuff runs just fine.oil is oil and synthetic stuff is a waist of money IMHO.but hey thats just me.
Old Jul 31, 2008 | 01:44 PM
irocbsa's Avatar
Fail.
Old Jul 31, 2008 | 01:59 PM
mzgp5x's Avatar
I run 20w-50 redline, or lucas syn. I also use lucas oil stabilizer. I like it. I have had good results with it. App...1997 CamaroSS 383 D1 M6.
Old Jul 31, 2008 | 02:05 PM
'94 Bad A Z28's Avatar
EXTREMELY thick, why?
Old Jul 31, 2008 | 02:42 PM
Originally Posted by irocbsa
Fail.
hey man i've ran the cheap stuff in all our cars.including the 11 sec LE2 T/A,and my current 12 sec bolt on nissan so it all works the same in my eyes lol.
Old Jul 31, 2008 | 03:56 PM
slomarao's Avatar
If you talk to the old timers they will talk very bad about 5w-30 oils. Well at least the guys i have run into over the years have.
I run 10w-30 and 40 depending on the seasons. If i had to pick one it would be 10w-30. Thats why i would use if i were you.
All the additives and other BS is junk. Dont run it. Most likely it will not cause any direct issues but the repeated use of it may. If your thinking about syn. oil and have over 75k on the motor dont do it. Still with the cheap stuff.
