Motor mounts, Tighten now or later?
Old Mar 23, 2006 | 08:46 PM
BMAN'S SCZ's Avatar
I am putting my motor back together finally. Do I tighten my motor brackets that go on the motor now or do I wait until it is in the car? It seems there is some play in the brackets when they are loose and I don't know if they will line up when I throw it in. What did you guys do. Thanks....john
Old Mar 23, 2006 | 09:59 PM
Birdman7389's Avatar
Re: Motor mounts, Tighten now or later?
I tightened mine before the install.....fwiw
Old Mar 23, 2006 | 10:05 PM
3gc's Avatar
3gc
I leave the bracket on the passenger side off and on the mount in the car, it just worked out easier for me that way. But I tightened it on the drivers side.
Old Mar 23, 2006 | 10:25 PM
kirschman's Avatar
I put my motor in bout a month ago. Tighten the mounts to the block, install the engine and put the bolts and nuts on the frame mounts. Leave em loose. I tightned mine up and when I installed the trans. i couldnt get the trans. mount to line up with the crossmember. Loosened the motor mount bolts (long ones) and it lined right up. My .O2
Old Mar 24, 2006 | 06:52 PM
BMAN'S SCZ's Avatar
Thanks guys, anyone else?
Old Mar 24, 2006 | 09:01 PM
LqMth's Avatar
I always have mine torqued to the block first. Have someone drop it down while you wait with the bolt. I always do the pass. side first because it seems to drop quicker, and then when that one is through use it as a pivot point and drop the driver side into place and put that bolt through.
HectorM52
Jul 30, 2017 11:46 AM
Rde Bandit
Mar 21, 2015 10:17 PM
Jazsun
Dec 29, 2014 12:14 PM
Nostang 96z
Aug 31, 2002 12:01 PM
